Razer Barracuda X (2022) - Black
Quicklinx: HF5NWS00 Mfr#: RZ04-04430100-R3M1
Type: Headset
£83.33 ex VAT
£99.99 inc VAT
One headset to play them all - the Razer Barracuda X is a versatile, lightweight wireless gaming headset designed for seamless use across PC, PlayStation, Nintendo Switch, and Android.
Razer SmartSwitch Dual Wireless to quick toggle between Razer HyperSpeed Wireless Bluetooth, for Ideal convenience the headset can instantly switch between high-speed 2.4GHz, bluetooth mode for seamless audio as you hop between using your PC/console/phone respectively
250 g Ergonomic Design for all-day comfort both indoors/out, built for gaming marathons yet portable enough for daily commutes, its light weight build is complemented by breathable memory foam ear cushions and swiveling earcups for a snug, comfortable fit
Razer TriForce 40 mm drivers for high-end audio performance, patented 3-part driver design pushes out exceptional highs, mids, lows that doesn’t muddy, providing deeper gaming immersion, a more dynamic listening experience for music/videos
Detachable Razer HyperClear Cardioid Mic for crystal-clear voice capture when needed, while the mic is tuned to suppress background noise for enhanced voice capture during gaming, it can also be easily removed to make the headset more travel-friendly for mobile use
On-Headset Controls for Ideal convenience, enjoy effortless control over your music, videos, call with easily accessible buttons located underneath the Razer Barracuda X’s earcups
  • USB-C wireless dongle
    No extra pairing steps, no additional software downloads, no trouble. Simply plug in the USB-C wireless transceiver to your desired platform and 4-in-1 wireless headset is immediately paired for play. A 3.5mm analog cable is available to turn the headset wired when needed.
  • Lightweight ergonomic design
    Ultra-light at just 250g, multi-platform wireless headset has been designed for long-lasting comfort and all-day use.
  • Razer TriForce?40mm drivers
    The patented design enables acoustic engineers to custom-tune each audio driver as though there are three, allowing for the individual replications of high, mid and low audio frequencies. This not only delivers richer trebles, brighter midrange, and powerful bass, but results in clear sound that doesn't muddy.
  • Razer?Hyperclear?cardioid mic
    By suppressing sounds from the back and sides, the mic offers greater speech pickup and noise cancellation, ensuring improved clarity and a natural representation of your voice.
Razer Barracuda X - headset
Headset - Bluetooth / 2.4 GHz radio frequency - wireless, wired - 3.5 mm jack, USB-C
Recommended Use
Game console, portable electronics, computer
Gaming
Headphones Form Factor
Full size
Wireless, wired
Wireless Technology
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB/mW
Impedance
32 Ohm
Noise Isolating
Microphone
Boom
Microphone Operation Mode
Cardioid (uni-directional)
Controls
Volume, answer/end, microphone on/mute, play/pause, next/previous track, skip track
250 g
Earpad Material
FlowKnit memory foam
Recommended Use
Gaming
Audio Output
Full size
Wireless, wired
Wireless Technology
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Sound Effects
Noise Isolating
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB/mW
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Razer Triforce titanium
Microphone
Boom
Detachable headset microphone
Sensitivity
-42 dB
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
Headset (mini-phone stereo 3.5 mm) , Power input (24 pin USB-C)
Cable
Cable Length
1.5 m
USB-C wireless transmitter
Cable Details
USB-C charge cable - detachable - 1.5 m , Audio cable - detachable - 1.3 m , USB extension cable - detachable - 1.5 m
Headset battery
Run Time (Up To)
50 hour(s)
Type: Headset
Brand: Razer
