Own the moment with the Ray-Ban Meta collection. Iconic style meets the latest in wearable tech that's designed to help you make the most of [everyday and extraordinary experiences/life as you live it]. Capture and share exactly what you see with a video call or live-stream, bringing people closer to your world. Move through your day with your favourite playlist or make a hands-free call or text, without stopping your flow. All while you stay present in the moment.
Stay in the moment with hands-free commands
Use your voice to call, text and capture content – all without missing what's in front of you.
Video call hands-free
Video call hands-free and share your POV so others can feel like they're right there with you whether you're cooking, watching a game or sharing core memories.
Capture
Capture your world with an updated camera and built-in edit features. Take high-quality photos and videos hands-free or live-stream your point of view.
Open-ear speakers
Discreet open-ear speakers let you enjoy rich audio quality, music and calls without losing the ambient sounds of your surroundings.
Voice commands
Use your voice to make calls and send messages on WhatsApp, Messenger and SMS – directly from your smart glasses.(1)
Social
Live in the moment and share your point of view by live-streaming directly from your glasses to Instagram and Facebook.
Speakers
Custom high-quality speakers deliver extended bass and high maximum volume for a rich listening experience, even in noisy or windy environments.
Charging Case
The sleek case lets you charge your glasses at home or on the go. Get up to four hours of battery life on a single charge, and up to 36 on a full charge.(2)
Meta View
The Meta View app helps you get the most out of Ray-Ban Meta smart glasses. Import, view and share photos, customise voice controls or manage settings to keep your glasses up to date. For ages 13+.
Box Contains:
Glasses, charging case, cleaning cloth, reference guide
(1)Voice features available in English, Italian and French.
(2)All battery life claims are approximate. Measured using pre-production hardware and mixed use scenario. Battery life varies by use, configuration, settings and many other factors. Actual results will vary.
Stylish design
The Ray-Ban | Meta Skyler smart glasses feature a fashionable cat-eye frame in shiny black, ensuring a trendy look while providing essential eye protection with 100% UVA and UVB shielding. -
High-quality audio
Equipped with a 5-microphone array and dual open-ear speakers, these smart glasses deliver immersive audio for calls and media, enhancing the user's experience without compromising sound quality. -
Advanced photography capabilities
Capture crystal-clear images with the 12-megapixel sensor and enjoy video recording at 1920 x 1440, making it easy to document moments and share them effortlessly. -
Convenient connectivity
Featuring Bluetooth 5.2 and multiple wireless standards, users can easily connect to devices for seamless media streaming and communication on-the-go. -
Hands-free operation
With voice input and Meta AI voice control, users can manage calls and operate the smart glasses without needing to use their hands, ensuring convenience in every interaction.
- Ray-Ban | Meta SKyler smart glasses - 32 GB - shiny chalky gray, gradient cinnamon pink
- Product Type
- Smart glasses
- Connectivity
- Wi-Fi 6, Bluetooth
- Storage
- 32 GB
- Camera
- 12 Megapixel
- Frame
- Cat eye shiny chalky gray
- Lens
- Gradient cinnamon pink - gradient
- Meta AI voice control, call handling, hands-free, live stream
- Supported Host Device OS
- iOS, Android
- Battery
- Rechargeable
- Battery Run Time
- Up to 4 hours
- Shiny chalky gray, gradient cinnamon pink
- 133 mm x 42 mm
- Length
- 150 mm
- 50 g
- Specific Absorption Rate (SAR)
- 0.34 W/kg (head) , 1.04 W/kg (body)
- Product Type
- Smart glasses
- Android 10 or later, iOS 14 or later
- Audio Input
- 5-microphone array
- Audio Output
- Dual open-ear speakers
- Wearing Style
- Glasses
Glasses
- Frame Shape
- Cat eye
- Frame Colour
- Shiny chalky gray
- Nose Bridge
- 20 mm
- Temple Arm Length
- 150 mm
- Lens Technology
- Gradient
- Lens Colour
- Lens Height
- 42 mm
Storage
- Capacity
- 32 GB
Camera
- Sensor Resolution
- 12 Megapixel
- Photos
- 4032 x 3024
- Videos
- 1920 x 1440
- Wireless Interface
- IEEE 802.11a/b/g/n/ac/ax, Bluetooth 5.2
Input Device
- Human Understanding Interface
- Voice input
- Rechargeable Battery
- Run Time (Up To)
- 4 hours
- Run Time Details
- Typical usage - up to 4 hour(s) , Typical usage with charging case - up to 36 hour(s)
- Length
- 150 mm
- Details
- Frame: 50 g , Charging case: 133 g
- Preloaded Software
- Meta View
- Protection
- 100% UVA protection, 100% UVB protection
- Included Accessories
- Charging case, cleaning cloth
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HN2T 050493 Condition: Customer return - item has been used and shows signs of use |
£126.78 |
Ref:
HN2T 050494 Condition: Customer return - item has been used and shows signs of use |
£129.31 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
