Qsan Technology S300Q-D212 36TB 2u 6G SAS-SAS SAN
Quicklinx: 98L6WS00 Mfr#: S300Q-D212/36TB
S300Q-D212/36TB 6G SAN system is specially designed for high availability applications.
Key Features -Two 6G SAS ports per controller
-Up to 70K IOPS & 3000MB/Sec. throughput
-Fully redundant & hot pluggable designs
-High connection availability: load balancing & failover
-Extendable capacity up to 120TB
Deliver the Best Price-Performance Value for SMB
Qsan's AegisSAN S300Q is designed for high availability, non-stop services, applications demanding high throughput, and flexible storage planning with cost effectiveness for small and medium businesses.
Highlights
 1.Two 6G SAS ports per controller
 2.Up to 70K IOPS & 3000MB/Sec. throughput
 3.Fully redundant & hot pluggable designs: RAID controllers, HDDs, power supplies, fan modules, battery backup modules, & JBOD expansion
 4.Green storage designs: auto disk spin down, advanced cooling mechanism, & 80 PLUS energy-efficient power supplies
 5.Advanced data protection: RAID 6, 60, QSnap writeable snapshot, Windows VSS support
 6.Flexible volume management for multiple applications & environments: virtualization (VMWare, Hyper-V, Citrix), cloud storage, SQL, Exchange, surveillance, file backup, email... etc
 7.High connection availability: load balancing & failover
 8.Extendable capacity up to 120TB
High Availability
S300Q 6G SAS system is specially designed for high availability applications. The S300Q has fully redundant components including redundant RAID controllers, power supplies, fan modules, battery backup modules and SAS JBOD expansion ports. All of these components are hot-swappable to create a high availability platform and provide non-stop services. Special features in firmware are RAID 6, 60 support, QSnap writable snapshot, Windows VSS support, and volume configuration restoration. All these features are designed to add an extra layer of protection to your valuable data. To raise the bar higher, S300Q can upgrade firmware without system down time. Both firmware image and volume handling are well protected by the redundant RAID controllers. When one RAID controller is down or disconnected, the other RAID controller will take over all tasks immediately and seamlessly.
Outstanding Performance
S300Q IOPS is 70,000 at maximum, much higher than other storage systems within the same segment in the current market; besides, its throughput is 3000MB/Sec. at maximum.
Applications
The optimized IOPS and throughput are capable of providing run-time critical online services, such as Cloud storage, SQL, Exchange, and high-end surveillance storages. Furthermore, with the 6G SAS interface, S300Q is ideal for virtualization environments - VMWare, Hyper-V, and Citrix. The data volumes can be managed easily and well protected by Qsan's advanced data protection features, and there will be no system downtime caused by single point of failure.
Green
All S300Q systems are equipped with Qsan's default green features for power saving. In most cases, the hard drives consume most power. With the auto disk spin down feature and proper configuration, the power consumption of hard drives can be reduced to a minimum, and users will not even notice this feature. S300Q monitors the environment temperature for cooling mechanism and the fan modules respond accordingly. The power supply modules are all 80 Plus Gold power efficient for better power converting rate. In virtue of the reduction of hard drive power consumption, the advanced cooling mechanism, and the energy-efficient power supplies, the unnecessary power cost is decreased greatly.
