Qsan Technology Q500-P10-D212 iSCSI 12 Bay SAN
Quicklinx: B7GCWS00 Mfr#: Q500-P10-D212
AegisSAN Q500-P10 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
AegisSAN Q500-P10 features six 1GbE iSCSI ports and one 1GbE management port to provide high availability & great performance for enterprises and SMB.
  • QiSOE (Qsan Hardware iSCSI Offload Engine)
    AegisSAN Q500 iSCSI series system features QiSOE (Qsan hardware iSCSI offload engine), which adopts a dedicated CPU core to process iSCSI packet. With QiSOE the performance will be booming up dramatically.
  • Virtualization technologies
    Virtualization refers to the creation of a virtual machine that acts like a real computer with an operating system. It adds a new layer of software and hardware between storage systems and servers so that applications no longer need to know on which specific drives, partitions or storage systems their data resides. This greatly enhances the flexibility, agility, scalability and manageability. AegisSAN Q500 storage system supports virtualization technologies of VMware, Citrix and Hyper-V enabling improved performance, superior scalability and better agility in the highly virtualized working environments.
  • Hardware redundancy
    Qsan storage systems are equipped with fully redundant components for all major functions, including dual active RAID controllers, power supplies, fan modules, battery backup modules, and SAS JBOD expansion ports. Being hot-swappable, all of them enable non-stop services for enterprises.
Qsan AegisSAN Q500-P10-D212 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
36 TB
iSCSI (1 GbE)
12 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Storage Controller Quantity
2
Hard Drive
12 x 3 TB HDD - hot-swap
SunSoft Solaris 10, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Microsoft Windows Server 2012, SunSoft Solaris 11, Microsoft Windows XP / 7
AC 120/230 V - 50/60 Hz
Power Redundancy
44.6 cm x 49.95 cm x 8.8 cm
3-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-2
Storage
36 TB
HDD Array External Interface
iSCSI (1 GbE)
Storage Controller
RAID (iSCSI)
Installed Qty
2
Interface Type
Data Transfer Rate
600 MBps
Cache / Buffer Size (Max)
8 GB (installed) / 16 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
Installed Qty
2
Hard Drive
HDD - hot-swap
12 x 3 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap
12 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 1000Base-T (management) - RJ-45
Built-in 2 cooling fans, hot-swappable fans
UL, BSMI, cUL, FCC, RoHS
2 x internal power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
400 Watt
80 PLUS Certification
80 PLUS
Power Factor Correction
44.6 cm
49.95 cm
8.8 cm
Limited warranty - 3 years ¦ Limited warranty - battery - 1 year
5 - 95% (non-condensing)
