QNAP VS-6120 Pro+ 20 Channel 6 Bay Desktop NVR NAS
Quicklinx: B53RWS00 Mfr#: VS-6120-PRO+-UK
Powered by the Intel dual-core processor and large memory, it delivers high performance at a throughput rate of 330 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 6-bay VS-6120 Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-6120 Pro+ can support large storage capacity, with 4TB on each hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard, Sanyo Denki system fan, and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-6120 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
  • Megapixel recordings
    The VioStor NVR supports megapixel recordings from various IP cameras.
  • Real-time digital watermarking
    The VioStor NVR supports real-time digital watermarking to protect the videos and snapshots from unauthorized modifications. The watermark proof utility is provided to verify whether or not the videos and snapshots are original.
  • High resolution local display
    The VioStor NVR provides an HDMI port which can be connected to an HDMI monitor or TV for doing monitoring in the full HD (1920 x 1080) resolution.
  • Convenient control of PTZ and speed dome cameras
    The PTZ cameras can be adjusted directly and the preset positions of the IP cameras can be viewed on the local display interface of the VioStor NVR.
  • Digital zoom
    Digital zoom of the video image is supported on the monitoring and playback interfaces of the NVR.
  • On-screen event alert
    When an event occurs, an alert icon will be shown instantly on the local monitoring page. The alert details can be viewed by clicking the alert icon.
  • Video search
    The VioStor NVR supports convenient video search by date and time on the local playback interface.
  • Local video playbacks on HDMI monitors or TVs
    The VioStor NVR supports direct video playbacks on HDMI monitors or TVs.
  • Smart control of PTZ & speed dome cameras
    The PTZ cameras can be directly adjusted by the web user interface of the VioStor NVR.
  • Instant event notification
    When the alarm recording is enabled and an event occurs, an alarm icon will be shown instantly on the monitoring page. The alert details can be viewed by clicking the icon.
  • Digital zoom
    Digital zoom (in/out) of the video image is supported on the monitoring and playback interfaces.
  • Dynamic E-map
    The VioStor NVR provides the E-map function for users to upload the digital maps and indicate the locations of the IP cameras of a monitoring location or region.
  • Multi-view Playback
    Use the multi-view playback feature to divide a video equally into multiple sessions for doing playback in a multi-view window, or play the videos of multiple IP cameras in the multi-view window simultaneously.
  • Video search by date and time, timeline, event, intelligent video analytics (IVA)
    The VioStor NVR supports quick video search by date and time, timeline, event, and intelligent video analytics (IVA), which includes motion detection, foreign object, missing object, out of focus, and camera occlusion.
  • Scheduled remote replication
    The VioStor NVR supports scheduled remote replication for performing secure data backup to a remote QNAP NAS on the local network.
  • One touch auto video backup
    Configure the one touch auto video backup button at the front of the NVR to copy the data from the NVR to an external storage device when the button is pressed.
  • Intel CPU and DDRIII memory for superior system performance
    Powered by the Intel CPU and DDRIII memory, the VioStor NVR delivers superior performance for surveillance applications.
  • CPU thermal solution with fan-less design
    Fan-less design provides better performance, quiet operation, lower energy costs, and enhanced reliability.
  • Touch-n-go PC-less installation
    Complete the first-time system installation, including hard disk initialization and RAID configuration, of the NVR by the LCD panel without using any PC.
  • Huge storage capacity for long-term recordings
    The VioStor NVR supports large physical storage capacity for recording a large amount of video data over a long period of time.
  • S.M.A.R.T. & advanced HDD Health Scanning (HHS)
    S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) helps monitor the hard disk drives status. The VioStor NVR supports HHS (HDD Health Scan) for doing disk checking and bad blocks scanning.
QNAP VioStor VS-6120 Pro+ NVR - standalone NVR - 20 channels
NVR - 20 channels - networked
IP Cameras Supported
20
Frame Rate
30 fps
Compression Format
MJPEG, MPEG-4, H.264
Image Resolution
1920x1080
Hard Drive(s) Supported
Quantity: 6
Voltage
100 - 240 V
26 cm x 23.5 cm x 18.5 cm
5.7 kg
Country Kits
United Kingdom
NVR
Video Channels
20
20
Image Resolution
1920x1080
Compression Format
Package Content
Manual, DVR, software, cables, mounting kit, DVR key
Network cable - RJ-45 - RJ-45 - 2 pcs.
Software Included (Y)
QNAP Finder, Drivers & Utilities
Country Kits
United Kingdom
VCCI, BSMI, FCC
Security DVR
Frame Rate (Record)
30 fps
Display Modes
6 split screens, 9 split screens, 8 split screens, 16 split screens, 4 split screens, 10 split screens, 12 split screens, 20 split screens
Playback Search
Date / time, event
Record Events
Alarm, scheduled, manual
Networked
RAID 5 support, RAID 0 support, RAID 1 support, JBOD support, RAID 5 hot spare support, RAID 6 hot spare support, Pan/Tilt/Zoom support, motion detection, key lock, security lock slot (cable lock sold separately), built-in LCD panel, e-mail alarm notifications
Hard Drive
Quantity Supported
6
Serial ATA
Removable
DDNS Support
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UPnP, SMB
Load balancing
Video Output Ports
HDMI x 1
Network Port
10/100/1000Base-T x 2
Other Ports
USB 2.0 x 5, VGA x 1, USB 3.0 x 2
Voltage
100 - 240 V
Frequency
50/60 Hz
Power Consumption
91 Watt
26 cm
23.5 cm
18.5 cm
5.7 kg
0 - 95%
