QNAP VS-2112PRO+ 2 Bay 12 Channel Desktop NVR NAS
Quicklinx: B540WS00 Mfr#: VS-2112-PRO+-UK
Powered by the Intel dual-core processor, it delivers high performance at a throughput rate of 180 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 2-bay VS-2112 Pro+ is designed for the SMB and small-office/home office segment with the features of robust performance, solid reliability and high-definition local display.
The VS-2112 Pro+ can accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-2112 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
  • High resolution local display
    The VioStor NVR provides an HDMI port which can be connected to an HDMI monitor or TV for doing monitoring in the full HD (1920 x 1080) resolution.
  • Convenient control of PTZ and speed dome cameras
    The PTZ (Pan/Tilt/Zoom) cameras can be adjusted directly and the preset positions of the IP cameras can be viewed on the local display interface of the VioStor NVR.
  • Digital zoom
    Digital zoom (in/out) of the video image is supported on the monitoring and playback interfaces of the NVR.
  • On-screen event alert
    When an event occurs, an alert icon will be shown instantly on the local monitoring page. The alert details can be viewed by clicking the alert icon.
  • Local video playbacks on HDMI monitors or TVs
    The VioStor NVR supports direct video playbacks on HDMI monitors or TVs.
  • Quick system setup
    The VioStor NVR can be set up in simple steps on the local display interface.
  • Preset position control and auto cruising
    The preset positions of an IP camera can be viewed by clicking the corresponding number buttons on the monitoring page. The time interval can also be configured on the PTZ cameras to perform periodic monitoring.
  • Instant event notifications
    When the alarm recording is enabled and an event occurs, an alarm icon will be shown instantly on the monitoring page. The alert details can be viewed by clicking the icon.
  • Dynamic E-map
    The VioStor NVR provides the E-map function for users to upload the digital maps and indicate the locations of the IP cameras of a monitoring location or region.
  • Multi-view playback
    Use the multi-view playback feature to divide a video equally into multiple sessions for doing playback in a multi-view window, or play the videos of multiple IP cameras in the multi-view window simultaneously.
  • Advanced event management
    The VioStor NVR supports various event handling options for different kinds of events.
  • Real-time SMS and email alert
    Configure the SMTP server and SMSC server settings on the NVR in order to receive instant system warnings or error messages by email and/or SMS.
  • Scheduled remote replication
    The VioStor NVR supports scheduled remote replication for performing secure data backup to a remote QNAP NAS on the local network.
  • One touch auto video backup
    Configure the one touch auto video backup button at the front of the NVR to copy the data from the NVR to an external storage device when the button is pressed.
  • CPU thermal solution with fan-less design
    Fan-less design provides better performance, quiet operation, lower energy costs, and enhanced reliability.
  • Linux embedded system
    The Linux-based VioStor NVR is more power-saving and less vulnerable to virus attacks compared to the PC-based surveillance solution.
  • Touch-N-Go PC-less installation
    Complete the first-time system installation, including hard disk initialization and RAID configuration, of the NVR by the LCD panel without using any PC.
  • Mobile surveillance by VMobile
    Use the VMobile network surveillance application on Android phone, Android Tablet, iPhone, iPad, or iPod touch to easily access video management functions such as remote live view and playback recordings.
  • Fisheye dewarping
    The fisheye dewarping function, available on the web and local display interface for specific camera models, assists in doing practical surveillance management, allowing the administrators to view the monitoring area in a clearer shape.
  • Host access control
    Specify the host or IP connections to be allowed or denied to access the NVR.
  • Advanced RAID with hot-swap design
    The VioStor NVR supports RAID 0, 1, single, and JBOD disk configurations. Its hot-swap design allows a failed drive of a disk volume (RAID 1 or above) to be replaced by hot swapping without turning off the server.
  • Automatic system startup after power recovery
    The VioStor NVR supports automatic system startup after a power recovery.
  • DOM architecture with embedded fail-safe Dual OS for enhanced reliability
    All the OS and applications of the VioStor NVR are embedded in the DOM. The VioStor NVR allows system booting without accessing the physical disk sectors to prevent from unsuccessful system startup caused by bad blocks or file errors on the hard drives.
QNAP VioStor VS-2112 Pro+ NVR - standalone NVR - 12 channels
NVR - 12 channels - networked
IP Cameras Supported
12
Compression Format
MJPEG, MPEG-4, H.264
Image Resolution
1920x1080
Hard Drive(s) Supported
Quantity: 2
Voltage
100 - 240 V
10.2 cm x 21.8 cm x 15.4 cm
2.5 kg
Country Kits
Europe
NVR
Video Channels
12
12
Image Resolution
1920x1080
Compression Format
Package Content
Manual, DVR, software, cables, mounting kit, DVR key
Network cable - RJ-45 - RJ-45 - 2 pcs.
Software Included (Y)
QNAP Finder, Drivers & Utilities
Country Kits
Europe
VCCI, BSMI, FCC
Security DVR
Display Modes
6 split screens, 9 split screens, 8 split screens, 4 split screens, 10 split screens, 12 split screens
Playback Search
Date / time, event
Record Events
Alarm, scheduled, manual
Networked
RAID 0 support, RAID 1 support, JBOD support, watermark, Pan/Tilt/Zoom support, motion detection, key lock, security lock slot (cable lock sold separately)
Hard Drive
Quantity Supported
2
Serial ATA
Removable
DDNS Support
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UPnP, SMB, CIFS
Load balancing
Video Output Ports
HDMI x 1
Network Port
10/100/1000Base-T x 2
Other Ports
USB 2.0 x 4, USB 3.0 x 1
Voltage
100 - 240 V
Frequency
50/60 Hz
Power Consumption
39.3 Watt
10.2 cm
21.8 cm
15.4 cm
2.5 kg
0 - 95%
