Powered by the Intel dual-core processor, it delivers high performance at a throughput rate of 180 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 2-bay VS-2112 Pro+ is designed for the SMB and small-office/home office segment with the features of robust performance, solid reliability and high-definition local display.
The VS-2112 Pro+ can accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-2112 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
High resolution local display
The VioStor NVR provides an HDMI port which can be connected to an HDMI monitor or TV for doing monitoring in the full HD (1920 x 1080) resolution. -
Convenient control of PTZ and speed dome cameras
The PTZ (Pan/Tilt/Zoom) cameras can be adjusted directly and the preset positions of the IP cameras can be viewed on the local display interface of the VioStor NVR. -
Digital zoom
Digital zoom (in/out) of the video image is supported on the monitoring and playback interfaces of the NVR. -
On-screen event alert
When an event occurs, an alert icon will be shown instantly on the local monitoring page. The alert details can be viewed by clicking the alert icon. -
Local video playbacks on HDMI monitors or TVs
The VioStor NVR supports direct video playbacks on HDMI monitors or TVs. -
Quick system setup
The VioStor NVR can be set up in simple steps on the local display interface. -
Preset position control and auto cruising
The preset positions of an IP camera can be viewed by clicking the corresponding number buttons on the monitoring page. The time interval can also be configured on the PTZ cameras to perform periodic monitoring. -
Instant event notifications
When the alarm recording is enabled and an event occurs, an alarm icon will be shown instantly on the monitoring page. The alert details can be viewed by clicking the icon. -
Dynamic E-map
The VioStor NVR provides the E-map function for users to upload the digital maps and indicate the locations of the IP cameras of a monitoring location or region. -
Multi-view playback
Use the multi-view playback feature to divide a video equally into multiple sessions for doing playback in a multi-view window, or play the videos of multiple IP cameras in the multi-view window simultaneously. -
Advanced event management
The VioStor NVR supports various event handling options for different kinds of events. -
Real-time SMS and email alert
Configure the SMTP server and SMSC server settings on the NVR in order to receive instant system warnings or error messages by email and/or SMS. -
Scheduled remote replication
The VioStor NVR supports scheduled remote replication for performing secure data backup to a remote QNAP NAS on the local network. -
One touch auto video backup
Configure the one touch auto video backup button at the front of the NVR to copy the data from the NVR to an external storage device when the button is pressed. -
CPU thermal solution with fan-less design
Fan-less design provides better performance, quiet operation, lower energy costs, and enhanced reliability. -
Linux embedded system
The Linux-based VioStor NVR is more power-saving and less vulnerable to virus attacks compared to the PC-based surveillance solution. -
Touch-N-Go PC-less installation
Complete the first-time system installation, including hard disk initialization and RAID configuration, of the NVR by the LCD panel without using any PC. -
Mobile surveillance by VMobile
Use the VMobile network surveillance application on Android phone, Android Tablet, iPhone, iPad, or iPod touch to easily access video management functions such as remote live view and playback recordings. -
Fisheye dewarping
The fisheye dewarping function, available on the web and local display interface for specific camera models, assists in doing practical surveillance management, allowing the administrators to view the monitoring area in a clearer shape. -
Host access control
Specify the host or IP connections to be allowed or denied to access the NVR. -
Advanced RAID with hot-swap design
The VioStor NVR supports RAID 0, 1, single, and JBOD disk configurations. Its hot-swap design allows a failed drive of a disk volume (RAID 1 or above) to be replaced by hot swapping without turning off the server. -
Automatic system startup after power recovery
The VioStor NVR supports automatic system startup after a power recovery. -
DOM architecture with embedded fail-safe Dual OS for enhanced reliability
All the OS and applications of the VioStor NVR are embedded in the DOM. The VioStor NVR allows system booting without accessing the physical disk sectors to prevent from unsuccessful system startup caused by bad blocks or file errors on the hard drives.
- QNAP VioStor VS-2112 Pro+ NVR - standalone NVR - 12 channels
- NVR - 12 channels - networked
- IP Cameras Supported
- 12
- Compression Format
- MJPEG, MPEG-4, H.264
- Image Resolution
- 1920x1080
- Hard Drive(s) Supported
- Quantity: 2
- Voltage
- 100 - 240 V
- 10.2 cm x 21.8 cm x 15.4 cm
- 2.5 kg
- Country Kits
- Europe
- NVR
- Video Channels
- 12
- 12
- Image Resolution
- 1920x1080
- Package Content
- Manual, DVR, software, cables, mounting kit, DVR key
- Cables Included
- Network cable - RJ-45 - RJ-45 - 2 pcs.
- Software Included (Y)
- QNAP Finder, Drivers & Utilities
- Country Kits
- Europe
- VCCI, BSMI, FCC
Security DVR
- Display Modes
- 6 split screens, 9 split screens, 8 split screens, 4 split screens, 10 split screens, 12 split screens
- Playback Search
- Date / time, event
- Record Events
- Alarm, scheduled, manual
- Networked
- RAID 0 support, RAID 1 support, JBOD support, watermark, Pan/Tilt/Zoom support, motion detection, key lock, security lock slot (cable lock sold separately)
Hard Drive
- Quantity Supported
- 2
- Interface
- Serial ATA
- Removable
- DDNS Support
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UPnP, SMB, CIFS
- Load balancing
- Video Output Ports
- HDMI x 1
- Network Port
- 10/100/1000Base-T x 2
- Other Ports
- USB 2.0 x 4, USB 3.0 x 1
- Voltage
- 100 - 240 V
- Frequency
- 50/60 Hz
- Power Consumption
- 39.3 Watt
- 10.2 cm
- 21.8 cm
- 15.4 cm
- 2.5 kg
- 0 °C
- 40 °C
- 0 - 95%
