QNAP TX-800P/24TB(8x3TB Seagate E-NAS HDD) 8 bay Desktop NAS
Quicklinx: CC71WS00 Mfr#: TX-800P/24TB-SENAS
When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased costs. QNAP TX-800P expansion enclosure provides a flexible expansion alternative designed with easy setup in mind for scaling up Thunderbolt NAS storage space via high-speed Thunderbolt 2 (20Gbps) cables. The TX-800P provides an additional 8 hard drives providing up to 64 TB expanded capacity for the Thunderbolt NAS, making it ideal for data backup, 4K digital media collection and video surveillance storage with blazing-fast data transmission performance.
  • Easily add additional drive capacity to a Thunderbolt NAS
    Simply connect the TX-800P to a Thunderbolt NAS via Thunderbolt 2 cables and power it on. The Thunderbolt NAS will automatically detect the hard drives in the TX-800P as newly-installed local drives. The Thunderbolt NAS capacity can then be seamlessly expanded as a large volume by using the powerful QTS Storage Manager.
  • Missing mode protection
    If your TX-800P is accidentally disconnected, the Thunderbolt NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact.
  • Powerful QTS Storage Manager
    The QTS Storage Manager neatly presents tools and options for managing system storage with a modern & intuitive graphical user interface, which greatly simplifies the process of NAS capacity expansion and TX-800P management. IT administrators can easily monitor the health status of TX-800P and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quick maintenance.
  • Efficient backup solution for Thunderbolt NAS
    In addition to expanding an existing volume, you can use the TX-800P as a flexible external storage to perform speedy and secure backup tasks for the Thunderbolt NAS. The QNAP RTRR (Real-Time Remote Replication) or rsync service lets IT administrators back up Thunderbolt NAS data to the TX-800P on a real time or scheduled basis.
  • Smart power design
    The TX-800P automatically powers on and off with your Thunderbolt NAS, allowing for total convenience and energy saving.
  • Flexible drive selection
    The TX-800P offers high flexibility in hard drive selection. IT administrators can choose low-cost but high-capacity SATA HDDs for large data archiving, or high-speed and high-stability SSDs for I/O intensive operations.
  • Excellent hardware design
    The TX-800P includes a full 350W internal PSU to provide ample power even under sustained full load. The well-ventilated chassis and smart fan helps to provide efficient cooling for better stability and reliability, with the fan enabling efficient heat removal even when all 8 drives are under full operation simultaneously.
QNAP TX-800P - hard drive array
Hard drive array
Total Array Capacity
24 TB
Thunderbolt 2
8 (installed) / 8 (max)
Supported Drives
SATA-600
Built-in Devices
Status LCD
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
8 x 3 TB HDD SATA 6Gb/s
AC 120/230 V - 50/60 Hz
29.82 cm x 23.54 cm x 18.52 cm
7.3 kg
Hard drive array
Chassis
Built-in Devices
Status LCD
8
Supported Devices / Modules Qty
8
Supported Drives
SATA-600
Storage
24 TB
HDD Array External Interface
Thunderbolt 2
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hard Drive
HDD
8 x 3 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
2 x Thunderbolt 2
Security lock slot (cable lock sold separately), built-in 2 cooling fans
Internal power supply
Power Provided
250 Watt
29.82 cm
23.54 cm
18.52 cm
7.3 kg
5 °C
35 °C
5 - 95% (non-condensing)
