QNAP TX-500P/20TB-RED 5 Bay Desktop NAS
Quicklinx: C602WS00 Mfr#: TX-500P/20TB-RED
When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased costs. QNAP TX-500P expansion enclosure provides a flexible expansion alternative designed with easy setup in mind for scaling up your NAS storage space. The TX-500P provides an additional 5 hard drives providing expanded capacity for the NAS, making it ideal for data backup, 4K digital media collection and video surveillance storage with blazing-fast data transmission performance.
  • Easily add additional drive capacity to your NAS
    Simply connect the TX-500P to the NAS and power it on. The NAS will automatically detect the hard drives in the TX-500P as newly installed local drives. The Thunderbolt NAS capacity can then be seamlessly expanded as a large volume.
  • Missing mode protection
    If your TX-500P is accidentally disconnected, your NAS enters the missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact.
  • Efficient backup solution
    In addition to expanding an existing volume, you can use the TX-500P as a flexible external storage to perform speedy and secure backup tasks for your NAS. The QNAP RTRR or rsync service lets IT administrators back up NAS data to the TX-500P on a real-time or scheduled basis.
  • Smart power design
    The TX-500P automatically powers on and off with your NAS, allowing for total convenience and energy saving.
  • Flexible drive selection
    The TX-500P offers high flexibility in hard drive selection. IT administrators can choose high-capacity SATA HDDs for large data archiving, or high-speed and high-stability SSDs for I/O intensive operations.
  • Excellent hardware design
    The TX-500P includes a full internal PSU to provide ample power even under sustained full load. The well-ventilated chassis and smart fan help to provide efficient cooling for better stability and reliability, with the fan enabling efficient heat removal even when all 5 drives are under full operation simultaneously.
QNAP TX-500P - hard drive array
Hard drive array
Total Array Capacity
20 TB
Thunderbolt 2
5 (installed) / 5 (max)
Supported Drives
SATA-600
Built-in Devices
Status LCD
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
5 x 4 TB HDD
AC 120/230 V - 50/60 Hz
21.06 cm x 23.54 cm x 18.52 cm
5.1 kg
Hard drive array
Chassis
Built-in Devices
Status LCD
5
Supported Devices / Modules Qty
5
Supported Drives
SATA-600
Storage
20 TB
HDD Array External Interface
Thunderbolt 2
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hard Drive
HDD
5 x 4 TB
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
2 x Thunderbolt 2
Security lock slot (cable lock sold separately), built-in cooling fan
Internal power supply
Power Provided
250 watt
21.06 cm
23.54 cm
18.52 cm
5.1 kg
5 °C
35 °C
5 - 95% (non-condensing)
