QNAP TVS-EC2480U-SAS-RP R2 is the world's first unified NAS supporting Auto Tiering to deliver ongoing optimization of data across high-performance SSD, 12Gbps SAS drives and high-capacity SATA disks. Powered by an Intel Xeon E3 CPU, the 40GbE-ready TVS-EC2480U-SAS-RP R2 delivers exceptional performance and supports cross-platform file sharing, comprehensive backup solutions, iSCSI & virtualization applications, and more practical business functions. With the powerful QTS operating system, the TVS-EC2480U-SAS-RP R2 performs as a reliable, scalable and unbeatable unified and tiered storage solution for businesses.
Enable Auto Tiering with Qtier technology
QNAP's Qtier Technology empowers the TVS-EC2480U-SAS-RP R2 with Auto Tiering that helps continuously optimize storage efficiency. With Auto Tiering, the TVS-EC2480U-SAS-RP R2 can automatically move hot data to high-performance storage tiers and cold data to lower-cost, higher-capacity drives, making the TVS-EC2480U-SAS-RP R2 an extremely efficient shared resource. Businesses will no longer have to invest heavily in expensive Flash technology, but can still enjoy exceptional application performance and lower TCO of storage from Auto Tiering with the TVS-EC2480U-SAS-RP R2. -
12Gbps DataBolt advantage
Implementing DataBolt technology, the TVS-EC2480U-SAS-RP R2 can deliver twice the throughput for 6Gbps SAS drives by automatically aggregating the bandwidth from 3Gbps and 6Gbps drives to fully utilize 12Gbps, effectively accelerating the existing infrastructure. -
Excellent performance
The TVS-EC2480U-SAS-RP R2 supports 12Gbps SAS drives to provide fast data transmission speeds and drive up to 3,812 MB/s throughput and 267,726 IOPS. Powered by an Intel Xeon E3 v3 quad-core processor with 16GB DDR3 or 8GB DDR3 ECC RAM, the TVS-EC2480U-SAS-RP R2 greatly enhances the efficiency of CPU-demanding tasks and serves more concurrent tasks. -
SSD cache acceleration
The TVS-EC2480U-SAS-RP R2 features 2 pre-installed 128GB mSATA modules, and there are no limits on using SSDs for caching. By installing high-performance SSDs, the IOPS performance of storage volumes can remarkably boost. It is perfect for improving overall workflow of random IOPS demanding applications such as database and virtualization. The internal cache port design reserves the space of hard drive tray for more storage capacity. -
Removable motherboard drawer for easy maintenance
With the TVS-EC2480U-SAS-RP R2's removable motherboard drawer, IT administrators have easier access in upgrading/installing RAM, the internal cache, 40GbE adapter and other components. The motherboard itself can be removed and replaced without needing to remove the heavy TVS-EC2480U-SAS-RP R2 from the rack cabinet, making it especially useful in maintaining the TVS-EC2480U-SAS-RP R2 in data centers with multiple rack cabinets.
- QNAP TVS-EC2480U-SAS-RP R2 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 4U
- Installed Devices / Modules Qty
- 0 (installed) / 24 (max)
- 44.25 cm x 53.05 cm x 17.615 cm
- 23.08 kg ()
- Processor
- 1 x Intel Xeon E3-1246V3 3.5 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s / SAS 12Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Apple MacOS X or later
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 44.25 cm
- 53.05 cm
- 17.615 cm
- 23.08 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB (installed) / 32 GB (supported) - DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, ALERT notification, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, RADIUS support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- SSL, 256-bit AES
- IEEE 802.3ad (LACP), IEEE 802.1x, UPnP
- Expansion Bays
- 24 (total) / 24 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 0 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 3.0 x4 , 4 (total) / 2 (free) x DIMM 240-pin
- 4 x USB 2.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x Ethernet 10Gb - SFP+ , 1 x SAS 12Gb/s
- Cables Included
- 4 x network cable
- Audible alarm, built-in 4 cooling fans
- FIPS 140-2
- Included Accessories
- Rack mounting kit
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 650 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
