QNAP TVS-951X-2GB 9 Bay Desktop NAS
Quicklinx: DM9HWS00 Mfr#: TVS-951X-2G
  • Celeron
£627.95 ex VAT
£753.54 inc VAT
The TVS-951X is powered by a 7th-generation Intel Celeron 3865U low-power dual-core processor, with 2GB/8GB DDR4 dual-channel memory (up to 32GB) and features a hybrid drive bay design (including five 3.5-inch drive bays and four 2.5-inch SSD bays) that supports up to nine drives in the same physical space as a 5-bay NAS. When 2.5-inch SSDs are installed in their dedicated bays, you can enable SSD caching and Qtier auto-tiering technologies to boost overall system performance. As the price of SSDs continues to become more accessible, the TVS-951X provides a high-performance and budget-friendly storage solution for SMBs. The TVS-951X also features a built-in 10GBASE-T/NBASE-T port for you to build a 10GbE high-speed network environment.
QNAP TVS-951X - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 9 (max)
22.5 cm x 22.4 cm x 18.2 cm
3.53 kg
1 x Intel Celeron 3865U 1.8 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, 50, JBOD, 60, 50 hot spare, 10 hot spare, 60 hot spare
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
0 GB
22.5 cm
22.4 cm
18.2 cm
3.53 kg
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
(supported) 2 GB (installed) / 32 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60, RAID 50 hot spare, RAID 10 hot spare, RAID 60 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, download client, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, IPv4 support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support, VPN client
Encryption Algorithm
SSL, TLS, 256-bit AES, AES-NI
DLNA CERTIFIED, UPnP
Expansion Bays
5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5"
1 x Ethernet 10Gb - RJ-45 , 1 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x HDMI output , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
FIPS 140-2
External power adapter
AC 120/230 V
Power Provided
120 Watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
Sound Emission
17.6 dBA
Capacity: 0GB
Interface: 10 Gigabit Ethernet
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 9-bay
Brand: QNAP
Price Range Ex VAT: 500 - 750
