QNAP TVS-663-4G/36TB-Red  6 Bay Desktop NAS
Quicklinx: B55JWS00 Mfr#: TVS-663-4G/36TB-RED
Adorned with a box in gold color, the sophisticated TVS-663, featuring the easy-to-use QTS operating system, is a powerful, reliable, secure and scalable NAS solution designed for mission-critical and intensive business applications and to meet fast growing data storage needs. The TVS-663 supports 10GbE via optional PCI-E network expansion and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
  • High performance & efficiency
    The TVS-663 is equipped with the energy-efficient 64-bit AMD quad-core processor with DDR3 RAM, SATA 6 Gb/s, and 2 Gigabit LAN ports for lightning-fast multi-tasking. The TVS-663 is a powerful NAS that delivers up to 448 MB/s read & write speeds with 4 x GbE port configuration, and up to 1,441 MB/s with 10GbE configuration. The TVS-663's hardware-accelerated encryption engine provides unmatched encryption performance in its class, up to 680 MB/s with AES-256 bit full NAS volume encryption, boosting system performance & security while ensuring the safety of sensitive business data stored in the TVS-663. The next-gen AMD Radeon HD graphics provides hardware-accelerated transcoding performance and dual HDMI outputs with brilliant high-definition multimedia content playback. When installed with the Wi-Fi 802.11ac USB network adapter, the TVS-663 can offer remarkably high speeds for transferring large amount of files and streaming bandwidth-consuming multimedia.
  • QTS - simple and efficient
    Thanks to the intuitive user interface of QTS, system operations of the TVS-663 are smooth and handy. Its intelligent desktop allows you to find desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater operating efficiency.
  • 10GbE ready
    The TVS-663 offers 2 inbuilt Gigabit Ethernet ports and supports 10 Gigabit high speed networks by installing a 10GbE network adapter. The 10GbE-ready TVS-663 delivers lightning-fast data throughput. Coupled with its large storage capacity potential, the TVS-663 is perfect for data centers to store big data and excel in fast data transmission, and for 10GbE home lab environment for technical professionals.
  • Use your TVS-663 as a PC with the exclusive QvPC technology
    QNAP's exclusive QvPC technology consolidates a number of high-end technologies including VM integration, multimedia transcoding, HDMI output, cloud integration and NAS connection technologies, allowing users to operate the TVS-663 as a PC when they plug in a keyboard, mouse and monitor. With QvPC technology, the TVS-663 is transformed into a cost-effective device with PC functionalities for users to operate the system via "HybridDesk Station" on the screen to directly access stored data, run multiple applications, surf the web on Google Chrome or Mozilla Firefox, watch Full HD videos with up to 7.1 channel audio with XBMC, and much more.
  • More screen to see: QvPC 4K Ultra HD display via HDMI
    Capture more details with 4K resolution! Coupled with QvPC Technology, you can connect the TVS-663 to a 4K UHD monitor via HDMI to take advantage of 4K's impeccable image detail for increased productivity. Photographers can view sharper and clearer high-resolution images, and you can get a larger workspace with one monitor when managing virtual machines.
  • Run additional operating systems on the TVS-663
    With the support for AMD-V virtualization technology, the TVS-663 can operate the Virtualization Station, transforming the TVS-663 into a 2-in-a-box NAS that can function as an all-in-one NAS and a virtualization platform that supports multiple operating systems, fast virtual machine (VM) creation, VM import/export, snapshot, and enables desktop operations on web browsers. With the easy-to-use interface, you can centrally manage all of the VMs created on the TVS-663 with minimal effort. You can also download VMs on demand from online VM markets and import them to the TVS-663 without any complex procedures.
  • Enjoy the best audiovisual experience with HD station and dual HDMI
    QNAP's HD station integrates the powerful XBMC media player and web browser. The splendid user interface and support for crystal-clear 7.1-surround sound passthrough brings smooth playback of Full HD videos, providing you with the perfect home theater experience. The TVS-663 features dual HDMI outputs, allowing you to connect to two monitors to play the same content with concurrent 1080p HDMI displays. You can even watch YouTube videos, surf the web and manage the Turbo NAS using Google Chrome or Mozilla Firefox with multilingual keyboard input. The HD Station supports multi-tasking and user authentication so only authorized users can access data stored on the TVS-663 via HDMI monitors.
  • Real-time & offline HD video transcoding
    Powered by a hardware-accelerated transcoding engine, the TVS-663 delivers superior real-time Full HD video transcoding to convert videos in common formats to universal formats that can be smoothly played on PCs, mobile devices and Smart TVs. The TVS-663 allows you to enjoy instant videos on multiple devices - even those that lack computing power or have limited file format support - without the need for complicated and time-consuming file conversion.
QNAP TVS-663 Turbo NAS - NAS server - 36 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
36 TB
6 (installed) / 6 (max)
26.02 cm x 23.55 cm x 18.5 cm
1 x AMD 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
6 x 6 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
4 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003
NAS server
Host Connectivity
Gigabit Ethernet
36 TB
26.02 cm
23.55 cm
18.5 cm
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
1 x AMD 2.4 GHz
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap
6 x 6 TB
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
256-bit AES
UPnP
Security DVR
40
Expansion Bays
6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express
2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x HDMI output
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, lockable, built-in 2 cooling fans
Security Slot Type
Kensington security slot
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
