QNAP TVS-1282T3-i7-32G/32TB-REDP 12 Bay
Quicklinx: D690WS00 Mfr#: TVS-1282T3-I7-32G/32TB-REDP
  • Core i7
Exclusively providing a Thunderbolt/NAS/iSCSI SAN triple solution, the TVS-1282T3 features four Thunderbolt 3 ports to enable seamless collaboration between up to four Mac and Windows devices. Coupled with its higher bandwidth to smooth Ultra HD video transfer and online editing, the TVS-1282T3 is a perfect match for Thunderbolt-equipped users for Ultra HD workflows, file storage and high-speed sharing.
  • Extraordinary performance
    Featuring high-performance processors, the TVS-1282T3 drives outstanding system performance for CPU-demanding applications. The TVS-1282T3 Thunderbolt 3 NAS not only features Thunderbolt 3 technology for faster data transfer but also has dual 10GbE ports giving you incredible flexibility for network connectivity.
  • Highly efficient media collaboration
    The TVS-1282T3 is a perfect match for Thunderbolt 3-capable devices. The higher bandwidth is especially suited for creative professionals and enthusiasts from photographers, filmmakers to graphic designers who focus more on 3D workflows.
  • Advanced hardware for greater efficiency
    High-performance hardware, well-designed application functionalities and thoroughly planned usage scenarios alongside flexible expansion interface are distinctive cornerstones for realizing optimum performance and diverse applications.
  • Application-based partitioning
    Every application requires different performance. For example, surveillance station requires higher priority access to storage to ensure the integrity of recordings, while normal transmission speeds are sufficient for file sharing. However, when multiple applications are running on the same storage media, the required throughput level cannot be guaranteed as the storage media is busy handling I/O requests from all of them. The TVS-1282T3 supports three different types of storage media: M.2, SSD and SATA hard drives, and they can be configured as independent partitions for different applications, ensuring a sufficient throughput level for every application.
  • Triple solution
    The TVS-1282T3 can simultaneously run general Ethernet services in addition to the Thunderbolt 3 network, completely independently and with no bandwidth interference. As an unmatched NAS that combines Thunderbolt, NAS and iSCSI SAN into one box, the TVS-1282T3 prevents the restriction of DAS connecting to only one device, and breaks the cost barrier for creating 10GbE high-speed network environments.
  • Flexibly attach, share, and expand
    With four Thunderbolt 3 ports on the TVS-1282T3, you can flexibly arrange the connection of your computer workstations with the TVS-1282T3 and its storage expansion enclosures based on your needs.
  • Optimal collaboration
    When using multiple workstations to work together to speed up a project, you can connect each workstation separately to the Thunderbolt 3 ports on the TVS-1282T3 to enjoy simultaneous, speedy video editing.
QNAP TVS-1282T3 - NAS server - 32 TB
NAS server
Host Connectivity
10 Gigabit Ethernet
Total Storage Capacity
32 TB
8 (installed) / 12 (max)
36.99 cm x 31.98 cm x 23.46 cm
1 x Intel Core i7 7700 3.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 4 TB
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
RAM
32 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
10 Gigabit Ethernet
32 TB
36.99 cm
31.98 cm
23.46 cm
Built-in Devices
Stereo speakers, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
32 GB (installed) / 64 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
8 x 4 TB
Network / Transport Protocol
TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, IPv6 support, Access Control List (ACL) support, DHCP server, SMS alert, reset button, IPv4 support, DHCP client, 4K resolution support, cloud backup, Real-time Remote Replication (RTRR)
Encryption Algorithm
SSL, 128-bit AES, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) x hot-swap - 2.5"
Expansion Slots
2 x PCI Express 3.0 x4 , 1 x PCI Express 3.0 x8 , 2 (total) / 2 (free) x M.2
4 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb , 5 x USB 3.0 - Type A , 3 x HDMI output - Type A , 4 x Thunderbolt 3 , 1 x audio out - mini-jack , 2 x audio in - 6.3mm jack
6 x network cable
Built-in 3 cooling fans
FIPS 140-2
Mounting kit, remote control, 2 x M.2 SSD heatsink
Internal power supply
QNAP QTS 4.2
5 - 95% (non-condensing)
Sound Emission
21.6 dB
