QNAP TS-EC880U R2, featuring the easy-to-use QTS operating system, provides a reliable and scalable NAS solution to fulfill data backup, file synchronization and remote access. The TS-EC880U R2 delivers exceptional performance, and supports cross-platform file sharing, comprehensive backup solutions, iSCSI and virtualization applications, and many practical business functions, making it the ideal choice for SMBs to secure important business data. It also includes abundant multimedia applications backed by its powerful hardware specifications.
Simple and efficient
Thanks to QTS's intuitive user interface, system operations of the TS-EC880U R2 are smooth and handy. Its intelligent desktop allows you to find the desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater working efficiency. -
A smarter, faster way to search
Quickly and easily find documents, photos, videos, and music with Qsirch, QNAP's built-in NAS search application lets you find what you need by real-time, natural search. Simply type in as much as you know about what you are trying to find, including bits of the file name or even words/phrases in the document, and Qsirch will display a list of matches, complete with thumbnails, as you type. Qsirch even remembers your search history so you can quickly navigate to files you've previously searched for. Qsirch is a huge productivity boost - it greatly reduces the amount of time spent looking for files on the NAS so you can focus on other tasks. -
Breakthrough performance
Featuring with powerful processor and DDR3 ECC RAM, the TS-EC880U R2 greatly enhances efficiency of CPU-consuming tasks and serves more concurrent tasks at the same time. -
Internal cache port for IO acceleration
The TS-EC880U R2 supports two on-board mSATA internal cache ports, and SSDs can be used for caching. By installing mSATA flash modules the IOPS performance of storage volumes can remarkably boost. It is perfect for improving overall workflow of random IOPS demanding applications such as database and virtualization. The internal cache port design reserves the space of hard drive tray for more storage capacity. -
Removable motherboard drawer for easy maintenance
With the TS-EC880U R2's removable motherboard drawer, IT administrators have easier access in upgrading/installing components such as RAM, the internal cache and 10GbE adapter. The motherboard itself can be removed and replaced without needing to remove the heavy TS-EC880U R2 from the rack cabinet, making it especially useful in maintaining the TS-EC880U R2 in data centers with multiple rack cabinets. -
Seamless capacity expansion
The TS-EC880U R2 supports online capacity expansion by cascading multiple QNAP RAID expansion enclosures to meet the needs of growing business data. With the QNAP scale-up solution, raw storage capacity can be gradually expanded. It is especially useful for large data applications, such as video surveillance, data archiving, and TV broadcast storage, to name few.
- QNAP TS-EC880U-R2 - NAS server - 32 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 32 TB
- Installed Devices / Modules Qty
- 8 (installed) / 8 (max)
- 44.25 cm x 53.05 cm x 8.8 cm
- 14.39 kg ()
- Processor
- 1 x Intel Xeon E3-1246V3 3.5 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
- Hard Drive
- 8 x 4 TB
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003
- NAS server
- Host Connectivity
- Enclosure Type
- 32 TB
- 44.25 cm
- 53.05 cm
- 8.8 cm
- 14.39 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 32 GB (supported) - DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 8 x 4 TB
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, ALERT notification, LDAP support, WOL, Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, TFTP support, RADIUS support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, NAP, bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, Apple Time Machine compatible, LACP, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- SSL, TLS
- IEEE 802.3ad (LACP), IEEE 802.1x, UPnP
- Expansion Bays
- 8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 0 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 3.0 x4 , 4 (total) / 2 (free) x DIMM 240-pin
- 4 x USB 2.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x Ethernet 10Gb - SFP+
- Cables Included
- 4 x network cable
- Audible alarm, lockable, built-in 4 cooling fans
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 400 watt
- Software Included
- Drivers & Utilities
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
