QNAP TS-859 Pro+ 16TB Ultrastar NAS
Quicklinx: 7BXYWS00 Mfr#: TS-859 PRO+U/16B
  • Atom
Modern business faces the challenge of dramatic growth of digital data, including documents, emails, applications, and so on. To deploy the IT environment with a reliable, affordable and expandable storage center to securely store, share, and back up the digital assets has become an important task for the server managers of the SMB and entry-level enterprise nowadays.
TS-859 Pro+ houses up to eight 3.5-inch or 2.5-inch SATA hard disk drives, and is capable of delivering ultra high performance, reliability, and lower power consumption during intensive data transfers. The NAS is an efficient and powerful business storage center with advanced iSCSI services, cross-platform data sharing, and all-in-one server applications. With VMware Ready and Citrix Ready certification, and proven compatibility with Microsoft Hyper-V environment, the NAS is an ideal shared storage solution in the virtualized and clustered environment.
  • Affordable and flexible virtualization solution
    TS-859 Pro+ can be utilized as the network shared storage of VMware, Citrix virtualization environments and Windows clustered servers. Comparing with traditional SAN (Storage Area Network), the NAS is a competitive alternative with much lower setup and maintenance costs in an IP SAN.
  • Feature-rich and integrated applications for business
    The NAS supports file sharing across Windows, Mac, Linux, and UNIX platforms. Versatile business applications such as file server, FTP server, printer server, web server, and Windows AD (Active Directory) support are provided.
  • Storage expansion by Virtual Disk Drive (VDD)
    The NAS supports flexible storage expansion by stacking other iSCSI targets on the network via its built-in iSCSI initiator. The connected iSCSI targets are turned into "virtual disk drives" of the NAS to provide more storage capacity.
  • Superior performance and energy-saving design
    The NAS delivers superior performance and high reliability for critical business applications. It is optimized to achieve low noise and low power consumption for environment protection.
  • Advanced RAID management with hot-swap design
    Turbo NAS offers RAID 0, 1, 5, 5+ hot spare, 6, 6+ hot spare, single, and JBOD disk configurations. It also supports hot-swap design that a failed member drive of a RAID configuration can be replaced by hot swapping without turning off the server.
  • Smart fan
    The fan rotation speed is automatically adjusted according to the server's temperature. You can also define the system temperatures to trigger high speed or low speed fan rotation. By manually setting the fan rotation speed, the fan will rotate at the defined speed continuously.
  • Policy-based automatic IP blocking
    To prevent the NAS from malicious attacks, you can create an IP filter policy to allow, deny, or auto-block the IP address or network domain which attempts to connect to the NAS via SSH/Telnet/HTTP(S)/FTP/Samba/AFP.
QNAP TS-859 Pro+ Turbo NAS - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
16 TB
8 (max)
1 x Intel Atom (Dual-Core)
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, JBOD, 5 hot spare, 6 hot spare
Hard Drive
8 hot-swap
Network adapter 1GbE
AC 120/230 V
NAS server
Host Connectivity
Gigabit Ethernet
16 TB
8 (max)
Processor / Memory
Processors Installed
1 x Intel Atom
Number of Cores
Dual-Core
Storage Controller
RAID
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, JBOD, RAID 5 hot spare, RAID 6 hot spare
Hard Drive
Hot-swap
8
Network adapter
1GbE
Internal
AC 120/230 V
Power Provided
350 Watt
