The TS-677 powered by AMD's new 14nm Ryzen processor redefines the high-end desktop business NAS for greater video and virtual machine performance with up to 6 cores/12 threads native processing and Turbo Core up to 3.6 GHz. Cutting-edge hardware integrated with multitasking software makes the TS-677 the preeminent choice to tackle resource-demanding applications and tasks.
Robust security
Equipped with 256-bit AES, AES-NI, FIPS 140-2, SSL, and TLS encryption algorithms, this NAS server ensures your data is protected with standard security measures. -
High-performance processing
Powered by an AMD Ryzen 5 processor with a 3.2 GHz base clock speed that can turbo up to 3.6 GHz and six cores, this device delivers exceptional performance for multitasking and demanding applications. -
Versatile connectivity
Offers a wide range of connectivity options including Ethernet 1000Base-T, USB 3.0, and PCI Express slots, providing flexibility for various network and peripheral connections. -
Comprehensive network services
Supports a plethora of network services and protocols including Apple Bonjour, DDNS, FTP, HTTP/S, Microsoft Active Directory, SMB, and more, making it a versatile choice for diverse network environments. -
Advanced storage solutions
Features Serial ATA-600 interface with support for RAID levels 0, 1, 5, 6, 10, and JBOD, offering flexible and secure data storage options to meet the needs of different users.
- QNAP TS-677 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 6 (max)
- 22.49 cm x 31.98 cm x 23.18 cm
- 7.7 kg ()
- Processor
- 1 x AMD Ryzen 5 1600 3.2 GHz (6-core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.3
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 22.49 cm
- 31.98 cm
- 23.18 cm
- 7.7 kg ()
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- 6-core
- Max Supported Qty
- 1
- Max Turbo Speed
- 3.6 GHz
- RAM
- 8 GB (installed) / 64 GB (supported) - DDR4
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
- Data Link Protocol
- TCP/IP, PPTP, L2TP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, LDAP support, VLAN support, WOL, Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, 256-bit encryption, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, TFTP support, RADIUS support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, NAP, bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, DLNA Media Server, Apple Time Machine compatible, LACP, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server, DLNA support
- Encryption Algorithm
- SSL, TLS, FIPS 140-2, 256-bit AES, AES-NI
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5" / 3.5" , 2 (total) / 2 (free) x hot-swap - 2.5"
- Expansion Slots
- 4 (total) / 2 (free) x DIMM 288-pin , 2 (total) / 2 (free) x M.2 , 1 (total) / 1 (free) x PCI Express 3.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 2.0 x4
- 4 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.1 - Type C , 1 x USB 3.1 - Type A , 6 x USB 3.0 - Type A , 2 x microphone - mini-jack , 1 x audio out - mini-jack , 2 x audio out
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), audible alarm, wake on LAN, built-in cooling fan
- Security Slot Type
- Kensington security slot
- Included Accessories
- 2 x M.2 SSD heatsink
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 250 watt
- QNAP QTS 4.3
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
