QNAP TS-653A-8G/6TB-RED 6 Bay Desktop NAS
Quicklinx: BYBKWS00 Mfr#: TS-653A-8G/6TB-RED
  • Celeron
  • Windows 8 (32/64 bits)
In response to the coming era of Internet of Things (IoT), the TS-653A innovatively supports the open-source Linux platform as a gateway for IoT solutions to other smart devices. The TS-653A allows users to directly utilize various feature-rich Liunx apps, enjoying a private cloud combining storage and IoT applications, and professional developers can develop and run IoT applications directly on the TS-653A. The secure, reliable TS-653A is packed with business-critical features such as Volume/LUN Snapshot - allowing files/folders to revert to a previous state in case of any corruption or file-loss. The TS-653A is powered by the latest quad-core Intel Celeron processor which allows users to enjoy 4K (H.264) video playback and 1080p/4K video real-time transcoding directly from the TS-653A to an HD/4K display.
  • Robust security
    Equipped with 256-bit AES encryption, the TS-653A ensures your data remains protected against unauthorized access, providing peace of mind for sensitive information.
  • Versatile connectivity
    With four Gigabit Ethernet ports, two HDMI outputs, and an audio out mini-jack, this NAS server offers multiple connectivity options for a wide range of devices and multimedia setups.
  • Comprehensive networking features
    Supporting a variety of networking protocols and services including DLNA, UPnP, Apple AirPlay, and VPN Server, the TS-653A enhances your network's functionality, making it ideal for diverse environments.
  • High-capacity storage solution
    With support for six hot-swap drives, the TS-653A provides flexible storage options, allowing for easy expansion and maintenance of your data storage capacity.
  • Efficient performance
    Powered by a quad-core Intel Celeron processor and DDR3L SDRAM, this NAS server delivers reliable and efficient performance for your data management needs.
QNAP TS-653A - NAS server - 6 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
6 TB
6 (installed) / 6 (max)
25.7 cm x 23.5 cm x 17.5 cm
5.2 kg ()
1 x Intel Celeron N3150 1.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
6 x 1 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
8 GB
AC 120/230 V (50 - 60 Hz)
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Gigabit Ethernet
6 TB
25.7 cm
23.5 cm
17.5 cm
5.2 kg ()
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap
6 x 1 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, video server, 256-bit encryption, firmware upgradable, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR)
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
40
Expansion Bays
6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 0 (free) x SO-DIMM 204-pin
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x microphone - 6.3mm jack , 2 x HDMI output , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, remote control, built-in cooling fan
FIPS 140-2
Remote control
Internal power supply
51.16 Watt
Power Provided
240 Watt
QNAP QTS 4.2
5 - 95% (non-condensing)
