QNAP TS-464 4-bay NAS Desktop
Quicklinx: HQ2CWS00 Mfr#: TS-464-8G
  • Celeron
£560.46 ex VAT
£672.55 inc VAT
TS-464 is a compact 4-bay NAS with superior performance. Supporting massive storage and 4TB M.2 SSD caching at an affordable price, the TS-464 fulfills your multitasking challenges for file management, backup, collaboration, and video conversion.
  • 2.5GbE NAS
    The 2.5GbE TS-464 NAS is as fast as a single-port 10GbE NAS. By setting port trunking with the two built-in 2.5GbE (2.5G/1G/100M) ports to unleash network potential and increase fault tolerance, TS-464 delivers fast transfer speeds.
  • Encryption engine
    Features Intel AES-NI 256 hardware-accelerated encryption to boost system performance while securing sensitive data.
  • Upgrade to dual-port 10GbE with a PCIe network card
    With a superior hardware design, you can install a dual-port 10GbE network card in the TS-464. Combining 10GbE networking, quad-core processor, and M.2 SSD caching, the TS-464 unleashes its full performance potential.
  • Expand storage capacity up to 16 hard drives
    TS-464 supports a storage capacity of up to 66TB by installing four 3.5-inch 22 TB hard drives in RAID 5. By connecting a TL-D1600S QNAP storage expansion unit, you can add an additional twelve hard drives to the TS-464 to achieve up to 280TB storage space to meet growing storage requirements.
  • Install M.2 NVMe SSDs for cache acceleration or efficient tiered storage
    If you have a huge number of small files requiring read/write operations, you can easily boost IOPS of TS-464 by configuring its two M.2 SSDs as a cache disk.
  • Accelerate AI - powered image recognition with TPU
    By leveraging an Edge TPU to QNAP AI Core (the AI-powered engine for image recognition), the TS-464 can perform high-speed face and object recognition. Edge TPU enables QuMagie to quickly process thousands of photos with high-speed AI Image recognition and classification, and QVR Face to analyze real-time video for instant facial recognition.
  • Abundant I/O capabilities with PCIe expansion
    QNAP offers a wide range of expansion cards to add versatile functions to your NAS. The TS-464 has one PCIe Gen 3 x2 slot that supports various expansion cards for expanding application potential.
  • Wi-Fi 6 adapter
    Install a Wi-Fi 6 adapter to turn the TS-464 into a Wi-Fi NAS, allowing accessing NAS data via wireless network.
  • Fast, smooth, and easy-to-use
    The TS-464 comes with the QTS 5 operating system as standard, providing a next-generation usage experience with an updated system kernel, optimized user interface, and advanced security features.
  • Get started with the notice board
    When performing first-time installation, the notice board guides you through the setup process. Simply follow the step-by-step instructions for a quick and easy setup.
  • Smooth and reactive user interface
    Whether clicking buttons, switching between apps, expanding/collapsing windows - every action is much smoother. The search bar in the main menu also assists in quickly finding desired apps.
  • Simple backup
    Superior hardware performance with an all-in-one Backup Solution to speed up backup/recovery tasks.
  • Back up data from one NAS to another NAS
    Back up data on a local NAS to another remote NAS using Hybrid Backup Sync. You can also deduplicate your backup using QuDedup to save time and storage space.
  • Smart storage
    QNAP's exclusive apps provide easy-to-use file storage and collaboration tools. Snapshots also help protect important data from Ransomware.
  • Smart snapshot space management
    QNAP supports smart snapshot space management to ensure there is enough storage space for new snapshots.
  • Smart surveillance
    TS-464 provides a professional surveillance NAS solution, compatible with 6,000+ IP cameras of 190+ brands and thousands of ONVIF network cameras.
  • Connect to HDMI monitor
    TS-464 supports has HDMI output for direct surveillance video playback, removing the need for a dedicated workstation.
QNAP TS-464 - NAS server
NAS server
Host Connectivity
2.5 Gigabit Ethernet
0 (installed) / 4 (max)
17 cm x 22.6 cm x 16.8 cm
2.26 kg ()
1 x Intel Celeron N5095 (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Performance
Concurrent connections (CIFS): 1500 - (with maximum memory) , Maximum pool size: 308 TB , Maximum number of storage pool: 128 , Maximum number of volume: 128 , Maximum shared folder size: 250 TB , Maximum number of shared folder: 512 , Maximum number of targets LUN: 256 , Minimum snapshot interval: 5 min , Maximum FTP connection: 1024 , Local user account: 4096 , Local group account: 512 , Domain user/group account: 200000 , Log recording: 3000 events per second , Virtual hosts: 32 , Maximum volume size: 250 TB , Maximum LUN size: 250 TB
RAM
8 GB
AC 100-240 V
Storage Operating System
QNAP QTS 5.0.1
Apple MacOS X 10.10 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 10 / 11, IBM AIX 7, Oracle Solaris 10 or later, Ubuntu 14.04, CentOS 7.0, Red Hat Enterprise Linux 6.6, SuSE Linux 12 or later
3-year warranty
NAS server
Host Connectivity
Total Storage Capacity
0 GB
17 cm
22.6 cm
16.8 cm
2.26 kg ()
Built-in Devices
IR sensor
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.9 GHz
RAM
8 GB
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
QuFTP, FTP, SFTP, TFTP, IPv4, IPv6, DDNS, QBelt, PPTP, L2TP, IPSec, WireGuard
Remote Management Protocol
SNMP 3, SNMP 2, SSH, Telnet, HTTPS, RADIUS
Network Services Compatibility
Microsoft CIFS, Apple File Protocol (AFP), Server Message Block (SMB), Network File System v3 (NFS v3), Network File System v4 (NFS v4), Web-based Distributed Authoring and Versioning (WebDAV)
Performance
Floating point unit, built-in hardware transcoding, SSD cache acceleration support, WOL, Jumbo Frames support, built-in buzzer, Storage Pool, SED Storage Pool, JBOD Expansion, VJBOD Cloud, fibre channel service, file-based iSCSI LUN, block-based iSCSI LUN, LUN mapping, LUN masking, WWPN Aliases Import/Export, FC Port Group, FC Port Binding, MPIO, online LUN capacity expansion, LUN snapshot, LUN snapshot replication and clone, auto tiering, RAID Group, RAID Level Migration, RAID Expansion, Storage Pool Expansion, RAID Hot Spare, RAID Sync/Rebuild/Scrubbing, EXT4 file system, Disk, Enclosure Locate, Disk S.M.A.R.T. Scan, Disk S.M.A.R.T. Data Migration, SSD trim, SSD life estimation, Disk Roaming, Disk Standby, Volume Snapshot, Snapshot Retention Policy, Self-serve Snapshot Recovery, Application Consisted Snapshot, Snapshot Full Clone, Snapshot Replica / Vault, SSD read-only Cache, SSD read-write cache, SSD write-only cache, SSD Cache RAID, SSD profiling tool, External Device Management, MTP, FXP support, file station, Object Storage, domain security, Domain Controller, shared folder permission, advanced folder permission, Windows ACL, group quota, folder quota, home folder, Resource Monitor, Network Recycle Bin, Smart Fan, schedule on/off, Virtual Switch, port trunking, VLAN support, DHCP server, security counselor, malware remover, 2-step verification, Allow/Deny List, Access Protection, Service binding, firewall protection, Qsync, HybridMount, Hyper Data Protector, Qsirch, QuMagie, HD Station, LDAP server, RADIUS support, SQL Server, DA Driver Analyzer, QuWAN, QmailAgent, Boxafe
Encryption Algorithm
AES-NI, 256-bit AES, FIPS 140-2, TLS 1.0, TLS 1.1, TLS 1.2, TLS 1.3
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x M.2 2280 , 1 (total) / 1 (free) x PCI Express 3.0 x2
2 x 2.5 Gigabit Ethernet - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.2 Gen 2 - Type A , 1 x HDMI output
1 x network cable
Dual boot, 120mm cooling fan, security lock slot (cable lock sold separately), Secure Erase
Security Slot Type
Kensington security slot
Power cable, 12 x flat head screws (for 3.5" HDD), 12 x flat head screws (for 2.5" HDD)
External power adapter
AC 100-240 V
40.536 Watt (with drives fully populated)
Power Consumption Stand by
21.618 Watt
Power Provided
90 Watt
QNAP QTS 5.0.1
Software Included
IronWolf Health Management, McAfee
Limited warranty - 3 years , Limited warranty - accessories - 1 year
Shipping Weight
3.6 kg
5 - 95% RH (non-condensing)
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Capacity: 0GB
Interface: 2.5 Gigabit Ethernet
Brand: QNAP
Price Range Ex VAT: £500 - £750
