Modern business faces the challenge of dramatic growth of digital data, including documents, e-mails, applications, and so on. To deploy the IT environment with a reliable, affordable and expandable storage center to securely store, share, and back up the digital assets has become an important task for the server managers of the SMB and entry-level enterprise nowadays.
TS-459 Pro+ houses up to four 3.5-inch or 2.5-inch SATA hard disk drives, incorporates Intel Atom 1.8GHz dual core processor and 1GB memory, and is capable of delivering ultra high performance, reliability, and lower power consumption during intensive data transfers. The NAS is an efficient and powerful business storage center with advanced iSCSI services, cross-platform data sharing, and all-in-one server applications. With VMware Ready and Citrix Ready certification, and proven compatibility with Microsoft Hyper-V environment, the NAS is an ideal shared storage solution in the virtualized and clustered environment.
Flexible multiple LUNs management
The NAS supports multiple LUNs (Logical Unit Numbers) and iSCSI targets. The LUNs can be flexibly mapped to, unmapped from, and switched among different iSCSI targets. -
Secure IP SAN environment deployment
Designed with CHAP authentication and LUN masking, the advanced ACL (Access Control List) offers you the capability to block the access from unauthorized initiators. -
Designed for virtualized and clustered environments
Comparing with the high cost of Fiber Channel SAN, Turbo NAS is an affordable system that can be deployed as a storage center for virtualized and clustered server environments, such as VMware, Citrix and Microsoft Windows Failover Cluster. -
Smart fan
The fan rotation speed is automatically adjusted according to the server's temperature. You can also define the system temperatures to trigger high speed or low speed fan rotation. By manually setting the fan rotation speed, the fan will rotate at the defined speed continuously. -
Policy-based automatic IP blocking
To prevent the NAS from malicious attacks, you can create an IP filter policy to allow, deny, or auto-block the IP address or network domain which attempts to connect to the NAS via SSH/Telnet/HTTP(S)/FTP/Samba/AFP. -
Syslog settings
All the system event logs and connection logs can be saved to a remote Syslog server. -
Detailed system information
You can view the system status, such as CPU usage, total memory, free memory, packets received, packets sent, error packets, system up time, CPU temperature, system temperature, hard disk drive temperature, and system fan speed. -
AES 256-bit volume-based data encryption
The disk volume with AES 256-bit encryption can only be accessed by an authorized encryption password or key. This prevents the NAS data from unauthorized access and data breach even if the hard disk drives were stolen.The data encryption functions may not available in accordance to the legislative restrictions of some countries. -
DOM architecture and fail-safe dual OS
Two operating systems are built on the DOM of Turbo NAS for system booting alternatively upon every system startup. When one fails, the other one will be used to boot up the NAS, and the failed OS is recoverable from the other healthy OS. -
Touch-and-go PC-less installation
You can use the front panel LCD display to complete the first time installation in a few simple steps. Turbo NAS will automatically complete the hard disk formatting and RAID building.
- QNAP TS-459 Pro+ Turbo NAS - NAS server - 4 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 18 cm x 23.5 cm x 17.7 cm
- Localisation
- Danish, Czech, English, German, French, Italian, Norwegian, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Chinese, Korean
- Processor
- 1 x Intel Atom D525 1.8 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, 5, 6, JBOD, 5 hot spare
- Hard Drive
- 4 x 1 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- RAM
- 1 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Linux
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / 2000 / XP, Microsoft Windows Server 2008
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 4 TB
- 18 cm
- 23.5 cm
- 17.7 cm
- Built-in Devices
- Status LCD
- Localisation
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 1 GB
- Flash Memory Installed
- 512 MB Flash
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- Data Transfer Rate
- 300 MBps
- Supported Devices
- Hard drive, disk array (RAID)
- Max Storage Devices Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 1 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP, UDP/IP, SMTP, FTP, DHCP, SMB
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- DHCP support, trunking, load balancing, wake on LAN (WOL), E-mail alert, print server, IPv6 support, IP address filtering, 256-bit encryption, firmware upgradable, MySQL server, web server, backup server, download client, file sharing, SSH support, iTunes server, Jumbo Frames support, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, UPnP Media Server
- IEEE 802.3ad (LACP), UPnP
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x eSATA 3Gb/s , 5 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 , 1 x VGA - HD-15
- Cables Included
- 2 x network cable
- Security Slot Type
- Kensington security slot
- Included Accessories
- Mounting kit
- Power Device
- Internal power supply
- Voltage Required
- 35 Watt
- Power Provided
- 250 Watt
- Linux
- Software Included
- Drivers & Utilities
- OS Required
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 34.1 dB
