QNAP TS-453S Pro (4G RAM) 4 Bay Desktop NAS
Quicklinx: BSR3WS00 Mfr#: TS-453S PRO-4G
  • Celeron
The TS-453S Pro, featuring the easy-to-use QTS operating system, is a powerful, reliable, secure and scalable NAS solution designed for mission-critical business applications and to meet fast growing data storage needs. The TS-453S Pro supports SATA 6 Gb/s drives and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
QNAP TS-453S Pro Turbo NAS - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 4 (max)
10.2 cm x 21.6 cm x 15 cm
1.74 kg ()
1 x Intel Celeron 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
24
RAM
4 GB
Storage Operating System
QNAP QTS 4.1
UNIX, Linux, Apple MacOS X or later, Microsoft Windows Server 2003 or later, Microsoft Windows 7 or later
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
10.2 cm
21.6 cm
15 cm
1.74 kg ()
Built-in Devices
Led panel, print server
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Network / Transport Protocol
TCP/IP, PPTP, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, proxy server, backup server, download client, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, iTunes server, Jumbo Frames support, DHCP server, Samba support, FTP server, SMS alert, IPv4 support, surveillance station, DLNA Media Server, Apple Time Machine compatible, NTP server, DHCP client, audible alarm notification, cloud backup, VPN Server, Apple AirPlay
Encryption Algorithm
SSL, FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
24
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x HDMI output - Type A
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
External power adapter
20.83 Watt
Power Provided
90 Watt
QNAP QTS 4.1
5 - 95% (non-condensing)
