QNAP TS-453DU-RP 4 Bay Rackmount with 4GB RAM inc Rail Kit
Quicklinx: G6BDWS00 Mfr#: TS-453DU-RP-4G
  • Celeron
£1,107.89 ex VAT
£1,329.46 inc VAT
The TS-453DU-RP features two 2.5GbE RJ45 ports, providing up to 2.5 times the speed of Gigabit Ethernet and enabling smoother multimedia playback and everyday usage. With a PCIe Gen 2.0 x 2 slot, the TS-453DU-RP provides flexibility in extending NAS functionality, allowing you to install various cards for extra network ports, M.2 SSD caching/tiering, or Wi-Fi connectivity. The TS-453DU-RP ensures data security with AES 256-bit encryption, boosting system performance while ensuring the safety of sensitive business data stored.
  • SSD caching and auto tiering for optimized storage efficiency
    The TS-453DU-RP supports SSD caching to improve the workflow of random IOPS demanding applications such as virtualization. Qtier Technology empowers the TS-453DU-RP with auto tiering that continuously optimizes storage utilization across high-performance SSD and high-capacity SATA drives. Qtier 2.0 features IO-awareness that empowers SSD tiered storage with a cache-like reserved space to handle burst I/O in real time, greatly maximizing the advantages of SSD.
  • Easy and secure file management
    File Station centralizes files stored on your TS-453DU-RP and in the cloud. You can easily upload files from your computer, drag and drop files between folders, rename files, delete files, and configure file and folder permissions to prevent unauthorized access. With Microsoft Office Online you can directly open and modify Microsoft Office documents stored on the TS-453DU-RP without having to download them to your local device. When sharing sensitive/confidential files on the TS-453DU-RP, use File Station to encrypt files into .qenc files, set a password, and use QENC Decrypter to decrypt the file.
  • Protect important data with snapshots
    Snapshots fully record the NAS system state and metadata and can be used to quickly restore files to previously-recorded states if they are accidentally deleted/modified or if the system is compromised by ransomware. QNAP snapshots are block-based and only record modified data. Not only does this save storage space, but also reduces the time required to back up and restore data.
  • Stay notified of system status and security
    Notification Center consolidates all QTS system events and alerts, providing you with a single-app solution for notifications. Security Counselor evaluates and recommends settings to improve NAS security.
  • Low-latency access to cloud-based data
    The TS-453DU-RP can be integrated with mainstream cloud services. By deploying cloud storage gateways and enabling local caching on the TS-453DU-RP, you can seamlessly use the cloud for storage, backup, and data recovery with low-latency access, providing an innovative hybrid cloud solution.
QNAP TS-453DU-RP - NAS server
NAS server
Host Connectivity
2.5 Gigabit Ethernet
0 (installed) / 4 (max)
17 cm x 22.6 cm x 16.8 cm
2.37 kg ()
1 x Intel Celeron J4125 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
2.5GbE
RAM
4 GB
AC 120/230 V
Power Redundancy
Storage Operating System
QNAP QTS 4.4.2
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019
NAS server
Host Connectivity
Total Storage Capacity
0 GB
17 cm
22.6 cm
16.8 cm
2.37 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.7 GHz
RAM
4 GB (installed) / 8 GB (supported) - DDR4
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
2.5GbE
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP, Network File System v3 (NFS v3), Network File System v4 (NFS v4)
NAT support, LDAP support, WOL, Syslog support, E-mail alert, firmware upgradable, STP support, download client, event log, ACL support, Jumbo Frames support, DHCP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, surveillance station, teaming support, DHCP client, static routing, cloud backup, VPN Server, Apple AirPlay, Link Aggregation, scheduler, VPN client, DLNA support, Chromecast support, port trunking, IFTTT agent, FXP support, Qcontactz, Qfinder Pro, IPv4 and IPv6 dual stack, OpenVPN server, VJBOD Cloud, myQNAPcloud, Qsync
Encryption Algorithm
SSL, TLS 1.0, TLS 1.1, TLS 1.2
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x SO-DIMM 260-pin , 2 (total) / 2 (free) x PCI Express 2.0
2 x 2.5 Gigabit Ethernet - RJ-45 , 2 x USB 3.2 Gen 1 - Type A , 3 x USB 2.0 - Type A , 1 x HDMI output
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
12 x flat head screws (for 2.5" HDD), 16 x flat head screws (for 3.5" HDD), 2 x power cables
Internal power supply
Power Redundancy
AC 120/230 V
QNAP QTS 4.4.2
Shipping Weight
3.6 kg
5 - 95% (non-condensing)
Sound Emission
21.1 dBA
Brand: QNAP
Price Range Ex VAT: £1000 - £1500
