QNAP TS-453BT3-8G 4 Bay NAS
Quicklinx: D68SWS00 Mfr#: TS-453BT3-8G
  • Windows 8 (32/64 bits)
  • Celeron
Featuring dual Thunderbolt 3 ports, coupled with M.2 SSD caching and 10GBase-T connectivity, the TS-453BT3 provides an ideal environment for professional collaborative media editing and high-speed file sharing. The TS-453BT3 features a sleek look with an OLED panel and two capacitive touch buttons. With powerful hardware capabilities and feature-rich productivity tools, the TS-453BT3 provides excellent NAS solution for media studios or small creative workgroups looking to greatly simplify their workflows.
  • Runs faster with Thunderbolt 3 and 10GbE connectivity
    Powered by an advanced processor, with DDR3L RAM, dual Gigabit LAN ports, and SATA 6G b/s drives, the TS-453BT3 delivers high read/write speeds and AES-NI encryption, delivering high performance while also maintaining the security of your data. You can also connect USB Type-C devices through the Thunderbolt 3 ports to transfer large media files across devices, brining you a more efficient workflows.
  • Direct access to 10GbE network from your Mac
    The innovative Thunderbolt-to-Ethernet converter (T2E) allows your Mac devices to access 10GbE networks via the TS-453BT3, providing flexible, convenient and highly-efficient data transfer without needing to buy extra adapters or converters.
  • Simple, sleek and trendy look
    The TS-453BT3 features a sliding cover design with tool-less 3.5-inch hard drive installation, making it easier for you to set up and maintain. The OLED front panel displays system information (including CPU temperatures, fan speed, and storage capacities of hard drives, volumes and LUN), allowing you to quickly view overall system status. Dust-proof capacitive touch buttons allow you to easily wake up the screen, change network IP settings and host password or even restart and shut down the system.
  • QTS - the intelligent and intuitive NAS operating system
    With multiple applications and functions, QTS enhances management efficiency, personal productivity, multimedia, and much more. The user-friendly QTS features an intelligent desktop that allows you to find desired functions quickly, monitor important system information on a real-time basis, open multiple application windows to run multiple tasks concurrently with greater working efficiency. Empowered by intelligent agent services that simplify system operations and management, QTS breaks down barriers of devices, platforms, and geography to provide you with the optimum cloud experience.
  • Qsirch finds what you need
    Qsirch is QNAP's full-text search engine that can quickly find desired files on your NAS. Qsirch can search through over 6,000 file formats and can use over 30 search conditions. Recommended or similar files are also displayed in the search preview page based on set keywords and conditions. Professional photographers can even search files through the camera's lens type, greatly shortening time in finding files and can spend more time concentrating on editing.
  • Easy storage expansion
    You need an easy solution to increase storage capacity when running out of space. QNAP provides several ways to expand your NAS storage as needed to accommodate data or business growth.
QNAP TS-453BT3 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet / Thunderbolt 3
0 (installed) / 4 (max)
17 cm x 22.6 cm x 16.8 cm
2.51 kg ()
1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
10Mb LAN, 100Mb LAN, 1GbE, 10GbE, Thunderbolt 3
RAM
8 GB
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
17 cm
22.6 cm
16.8 cm
2.51 kg ()
Built-in Devices
OLED display
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.3 GHz
RAM
8 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Hardware encryption, trunking, LDAP support, WOL, Syslog support, manageable, E-mail alert, print server, IPv6 support, video server, 256-bit encryption, firmware upgradable, proxy server, backup server, download client, file sharing, event log, TFTP support, ACL support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, RTRR
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5" , 2 (total) / 2 (free) x internal
Expansion Slots
2 (total) / 0 (free) x SO-DIMM 204-pin , 1 x PCI Express 2.0 x2
2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 , 2 x HDMI output , 2 x Thunderbolt 3 , 1 x Ethernet 10Gb
2 x network cable
Security lock slot (cable lock sold separately), remote control, built-in cooling fan
Security Slot Type
Kensington security slot
FIPS 140-2
Remote control, 12 x flat head screws (for 2.5" HDD), power cable
External power adapter
Power Provided
120 Watt
QNAP QTS 4.3
5 - 95% (non-condensing)
