QNAP TS-453A-4G/12TB-RED Desktop NAS
Quicklinx: BYBZWS00 Mfr#: TS-453A-4G/12TB-RED
  • Celeron
  • Windows 8 (32/64 bits)
In response to the coming era of Internet of Things (IoT), the TS-453A innovatively supports the open-source Linux platform as a gateway for IoT solutions to other smart devices. The TS-453A allows users to directly utilize various feature-rich Liunx apps, enjoying a private cloud combining storage and IoT applications, and professional developers can develop and run IoT applications directly on the TS-453A. The secure, reliable TS-453A is packed with business-critical features such as Volume/LUN Snapshot - allowing files/folders to revert to a previous state in case of any corruption or file-loss. The TS-453A is powered by the quad-core Intel Celeron processor which allows users to enjoy 4K (H.264) video playback and 1080p/4K video real-time transcoding directly from the TS-453A to an HD/4K display.
  • Robust security
    Equipped with 256-bit AES and FIPS 140-2 encryption algorithms, this NAS server ensures your data is protected with high-level security, making it ideal for sensitive information storage.
  • Versatile connectivity
    Featuring four Gigabit Ethernet ports, two HDMI outputs, and an audio out mini-jack, the TS-453A offers a range of connectivity options for various networking and multimedia needs.
  • Comprehensive networking features
    Supports a wide array of networking protocols and services including Apple AirPlay, BitTorrent Client, multiple server roles like VPN, FTP, and print server, ensuring it meets diverse network requirements.
  • High-performance processing
    Powered by an Intel Celeron quad-core processor with a clock speed of 1.6 GHz and equipped with DDR3L SDRAM, this NAS server delivers efficient and reliable performance for your data management needs.
  • Flexible storage options
    With support for up to 4 hot-swap drives and various RAID configurations including RAID 0, 1, 5, 6, and 10, it offers flexible storage solutions to meet the demands of different data storage and redundancy requirements.
QNAP TS-453A - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
18 cm x 23.5 cm x 17.7 cm
3.65 kg ()
1 x Intel Celeron N3150 1.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 3 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
4 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
18 cm
23.5 cm
17.7 cm
3.65 kg ()
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap - 3.5"
4 x 3 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, video server, 256-bit encryption, firmware upgradable, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR)
Encryption Algorithm
SSL, TLS, FIPS 140-2, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
40
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 0 (free) x SO-DIMM 204-pin
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x microphone - 6.3mm jack , 2 x HDMI output , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, remote control, built-in cooling fan
FIPS 140-2
Remote control
External power adapter
AC 120/230 V
32.35 Watt
Power Provided
96 Watt
QNAP QTS 4.2
5 - 95% (non-condensing)
