QNAP TS-451A-2G/12TB-RED 4 Bay NAS
Quicklinx: CK18WS00 Mfr#: TS-451A-2G/12TB-RED
  • Celeron
With the growing popularity of smartphones and cameras, a staggering amount of digital media is being created and downloaded every day. This media is also becoming increasingly larger in size, with Full HD movies available to download for mobile devices and 4K on the horizon for HDTVs and download services. This rise in file size makes it impossible for limited mobile devices to store large amounts of media, and also forces users to sacrifice quality for storage space. With the improved TS, QNAP offers customers a NAS with a large and scalable storage solution with a powerful processor and HDMI connectivity for home entertainment and QNAP's unique accelerated transcoding, that allows mobile devices to enjoy media with optimized resolutions and saving their local storage space. The TS also features QNAP's exclusive QvPC technology, that allows you to use a TS model as a PC by simply plugging in a keyboard, mouse and HDMI monitor - greatly extending its functionality and providing even more value for home users.
  • Robust security
    Equipped with 256-bit AES encryption and FIPS 140-2 compliance, this NAS server ensures your data is protected with high-level security measures.
  • Versatile connectivity
    Offers a wide range of interfaces including Ethernet 1000Base-T, USB 3.0, micro-USB 3.0, and HDMI output, providing flexible connection options for various devices.
  • Comprehensive networking features
    Supports numerous protocols and services like Apple AirPlay, BitTorrent Client, and VPN Server, making it a versatile tool for managing and sharing digital content across different platforms.
  • High-capacity storage
    With support for up to 4 hot-swap drives and various RAID configurations, it offers a flexible and reliable solution for expanding your storage capacity.
  • Efficient management
    Remote management protocols including SNMP, SSH, and HTTPS allow for easy and secure administration of the device from anywhere.
QNAP TS-451A-2G - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
12 TB
4 (installed) / 4 (max)
16 cm x 22.5 cm x 16.85 cm
3 kg ()
1 x Intel Celeron N3060 1.6 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 3 TB 24x7 continuous operation
Card Reader
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
32
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 10
NAS server
Host Connectivity
Gigabit Ethernet
12 TB
16 cm
22.5 cm
16.85 cm
3 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - 3.5"
4 x 3 TB
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, WOL, Syslog support, manageable, E-mail alert, print server, IPv6 support, video server, firmware upgradable, proxy server, backup server, download client, file sharing, event log, TFTP support, ACL support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay
Encryption Algorithm
FIPS 140-2, 128-bit AES, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
32
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 0 (free) x SO-DIMM 204-pin
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x micro-USB 3.0 - Type B , 1 x HDMI output , 1 x audio in - mini-jack , 1 x audio out - mini-jack
2 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
ISO 7779
Remote control
External power adapter
AC 120/230 V
27 watt
Power Provided
96 watt
QNAP QTS 4.2
5 - 95% (non-condensing)
Sound Emission
18.1 dBA
