QNAP TS-433-4G 4-bay NAS
Quicklinx: HQ2HWS00 Mfr#: TS-433-4G
£344.60 ex VAT
£413.52 inc VAT
Run your own personal cloud storage and enjoy easy file access, sharing, and syncing with the TS-433. Designed with a 2.5GbE port to enhance collaboration and increase remote work productivity, the TS-433 also features rich multimedia applications and provides a complete home entertainment portal.
QNAP TS-433 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 2.5 Gigabit Ethernet
0 (installed) / 4 (max)
16 cm x 21.9 cm x 16.9 cm
2.07 kg ()
1 x ARM A55 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 50, 60
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
RAM
4 GB
AC 100-240 V
Storage Operating System
QNAP QTS 5.0.0
5-year warranty
NAS server
Host Connectivity
Total Storage Capacity
0 GB
16 cm
21.9 cm
16.9 cm
2.07 kg ()
Processor / Memory
Processors Installed
1 x ARM A55 2 GHz
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 4 GB (supported)
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 50, RAID 60
Network / Transport Protocol
DHCP, iSCSI, DDNS, SMB, PPTP, L2TP, IPSec
Remote Management Protocol
SNMP 2, SNMP 3, SSH, HTTP, HTTPS, Telnet, TFTP
Network Services Compatibility
Apple File Protocol (AFP), Microsoft CIFS, Server Message Block (SMB), DHCP, DDNS, HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Network File System v3 (NFS v3), Network File System v4 (NFS v4)
VJBOD Cloud, EXT4 file system, online RAID level migration, SSD trim, FTP server, file station, ACL support, scheduler, system log, port trunking, VLAN support, DHCP server, anti-malware protection, firewall protection, Qsync, Qsirch, QuMagie, VPN support, LDAP support, RADIUS support, Q'center (NAS CMS), QmailAgent, QuWAN, SQL Server, 256-bit encryption, cloud backup, Apple Time Machine compatible, anti-virus protection, WOL, Jumbo Frames support, built-in buzzer
Encryption Algorithm
256-bit AES
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
1 x 2.5 Gigabit Ethernet - RJ-45 , 1 x USB 3.2 Gen 1 - Type A , 1 x Ethernet 1000 - RJ-45 , 2 x USB 2.0
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, reset button
Security Slot Type
Kensington security slot
12 x flat head screws (for 2.5" HDD), 16 x flat head screws (for 3.5" HDD), power cable, 2 x drive tray keys
External power adapter
AC 100-240 V
22.54 Watt
Power Consumption Stand by
8.45 Watt
Power Provided
90 Watt
QNAP QTS 5.0.0
Limited warranty - 5 years
Shipping Weight
3.5 kg
5 - 95% (non-condensing)
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Capacity: 0GB
Interface: 2.5 Gigabit Ethernet
Brand: QNAP
