QNAP TS-431P3-2G 4 Bay Desktop
Quicklinx: FZ6ZWS00 Mfr#: TS-431P3-2G
The TS-431P3 features a 2.5GbE RJ45 port, providing up to 2.5 times the speed of regular Gigabit Ethernet and enabling smoother multimedia playback and everyday usage. The TS-431P3 ensures data security by supporting AES 256-bit encryption and various local/remote/cloud backup options - including snapshot protection that allows for files and data to be reverted to previously-recorded states if they are accidentally deleted, modified or affected by malware.
  • Build a faster home network with QNAP
    The TS-431P3 includes a 1GbE port and a 2.5GbE port to provide a smoother NAS experience and multimedia playback. Additional network connection options from QNAP include USB 3.2 Gen 1 to 5GbE adapters (supports N-BASET/Multi-Gig), QXG 5GbE PCIe cards, and QNAP QSW 10GbE switches.
  • Easy and secure file management
    File Station allows direct management of files stored on the TS-431P3 and in the cloud. Users can easily upload files from their PC, drag/drop files between folders, rename/delete files, and configure file/folder permissions to prevent unauthorized access. Users can also use Microsoft Office Online to directly view/edit Microsoft Office documents stored on the TS-431P3. Confidential/sensitive data can also be encrypted to add extra security.
  • Protect important data with snapshots
    Snapshots help protect data by fully recording the NAS system state and metadata. With snapshots, users can quickly restore files to previously-recorded states if files are accidentally deleted or modified, or if the system is compromised by malware. QNAP snapshots are block-based and only record modified data. Not only does this save storage space, but also reduces the time required to back up and restore data.
  • Extend NAS functionality with containers and apps
    Container Station integrates LXC and Docker lightweight virtualization technologies, allowing users to host and operate containerized applications directly on the TS-431P3. With many popular and fully-configured applications available from the built-in Docker Hub (including for automation and multimedia), the TS-431P3 provides users with a vast array of potential functions and application capabilities.
  • Multiply your productivity
    The app-driven QTS operating system provides solutions for simplifying file backup, management, search, and more.
QNAP TS-431P3-2G - NAS server
NAS server
Host Connectivity
2.5 Gigabit Ethernet
0 (installed) / 4 (max)
16 cm x 21.9 cm x 16.9 cm
2.01 kg ()
1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
2.5GbE, 1GbE, 10Mb LAN, 100Mb LAN
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.4.2
Apple MacOS X 10.10 or later, CentOS 7.0, Red Hat Enterprise Linux 6.6, SuSE Linux 12 or later, Ubuntu 14.04, IBM AIX 7, Oracle Solaris 10, UNIX, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019
NAS server
Host Connectivity
Total Storage Capacity
0 GB
16 cm
21.9 cm
16.9 cm
2.01 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 8 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Network / Transport Protocol
TCP/IP, DDNS, FTP, SFTP, PPTP, L2TP, IPSec
Remote Management Protocol
HTTP, HTTPS, SSH, Telnet, SNMP 2, SNMP 3, TFTP
Network Services Compatibility
Web-based Distributed Authoring and Versioning (WebDAV), Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, FTP, DHCP, Network File System (NFS), DDNS, FTPS
IPv4 support, IPv6 support, port trunking, Jumbo Frames support, Link Aggregation, load balancing, DHCP client, DHCP server, NAT support, Spanning Tree Protocol (STP) support, E-mail alert, push notification, SMS alert, wake on LAN (WOL), LDAP support, FXP support, RTRR client, RTRR server, Rsync compatible, OpenVPN client, DNS server, VPN support, DLNA support, BitTorrent Client, IFTTT agent, Qmiix agent
Encryption Algorithm
256-bit AES, TLS 1.0, TLS 1.1, TLS 1.2, SSL, FIPS 140-2
UPnP
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 1 x 2.5 Gigabit Ethernet - RJ-45 , 3 x USB 3.2 Gen 1
1 x network cable
Reset button, built-in cooling fan, security lock slot (cable lock sold separately)
Security Slot Type
Kensington security slot
12 x flat head screws (for 2.5" HDD), 16 x flat head screws (for 3.5" HDD), power cable
External power adapter
AC 120/230 V
Power Provided
90 Watt
QNAP QTS 4.4.2
Shipping Weight
3.5 kg
5 - 95% (non-condensing)
Sound Emission
19.5 dBA
