QNAP TS-431P2-1G 4 Bay Desktop NAS
Quicklinx: D88JWS00 Mfr#: TS-431P2-1G
TS-431P2 features three USB 3.0 ports and dual Gigabit LAN ports, delivering outstanding multitasking performance for your backup, synchronization, and remote access needs on a secure private cloud. The quad-core TS-431P2 provides powerful hardware capabilities, enabling Qfiling (automated file organization) and Qsirch (full-text search) for more intelligent day-to-day NAS use.
  • Robust security
    Equipped with 256-bit AES, SSL, and TLS encryption algorithms, the TS-431P2 ensures your data remains protected against unauthorized access. Its Kensington security slot also offers a physical safeguard, providing peace of mind in data security.
  • Versatile connectivity
    With two Ethernet 1000Base-T ports and three Type-A connectors, the TS-431P2 offers flexible networking options. Whether for high-speed Internet access or connecting multiple devices, it caters to all your connectivity needs.
  • Comprehensive backup solutions
    Supporting a wide range of backup services including cloud backup, real-time remote replication (RTRR), and compatibility with Apple Time Machine, the TS-431P2 provides versatile options to secure your data across various platforms.
  • Advanced networking features
    From VPN Server capabilities to support for multiple network protocols like FTP, SMB, and iSCSI, the TS-431P2 is designed to enhance your network's functionality. Its support for Wi-Fi USB dongle also extends its connectivity options.
  • Efficient data management
    The NAS server supports RAID configurations including JBOD, RAID 0, RAID 1, RAID 10, RAID 5, and RAID 6, offering flexible options for data storage, redundancy, and performance optimization.
QNAP TS-431P2 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 4 (max)
16 cm x 21.9 cm x 16.9 cm
1.28 kg ()
1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, 1GbE
RAM
1 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
16 cm
21.9 cm
16.9 cm
1.28 kg ()
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
1 GB DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, WOL, Syslog support, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, download client, file sharing, event log, TFTP support, ACL support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SFTP client, Apple AirPlay, Dropbox support, Wi-Fi USB dongle support, RTRR, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support
Encryption Algorithm
SSL, TLS, 256-bit AES
UPnP
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, built-in cooling fan, hardware encryption, scheduled power on/off
Security Slot Type
AES-256
External power adapter
AC 120/230 V
Power Provided
65 Watt
QNAP QTS 4.3
5 - 95% (non-condensing)
Sound Emission
19.5 dBA
