The TS-431 is a powerful yet easy-to-use network storage center for backup, synchronization, remote access, and home entertainment. With the Notes Station, you can easily create digital notes on your private cloud and share with friends and colleagues at no extra cost. Powered by an advanced ARM Cortex A9 dual-core processor, the TS-431 delivers incredible performance as a home NAS with three USB 3.0, one eSATA, and dual LAN ports. The TS-431 can enhance your digital lifestyle.
- QNAP TS-431 - NAS server - 24 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 24 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 18 cm x 23.5 cm x 17.7 cm
- Processor
- 1 x ARM Cortex-A9 1.2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 4 x 6 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 512 MB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.1
- System Requirements
- UNIX, Linux, Apple MacOS X or later, Microsoft Windows Server 2003 or later, Microsoft Windows 7 or later
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 18 cm
- 23.5 cm
- 17.7 cm
- Built-in Devices
- Led panel, print server
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 6 TB
- Data Link Protocol
- TCP/IP, PPTP, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, 256-bit encryption, proxy server, web server, backup server, download client, file sharing, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, eMule client, NTP server, DHCP client, VPN Server, SNMP support, Apple AirPlay
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- DLNA CERTIFIED, UPnP
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x eSATA
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), audible alarm, built-in cooling fan, AirPlay, scheduled power on/off
- Security Slot Type
- Kensington security slot
- VCCI, C-Tick, BSMI, FCC
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 33.75 Watt
- Power Provided
- 90 Watt
- QNAP QTS 4.1
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
