The TS-431 is a powerful yet easy-to-use network storage center for backup, synchronization, remote access, and home entertainment. With the Notes Station, you can easily create digital notes on your private cloud and share with friends and colleagues at no extra cost. Powered by an advanced ARM Cortex dual-core processor, the TS-431 delivers incredible performance as a home NAS with three USB 3.0, one eSATA, and dual LAN ports. See how TS-431 can enhance your digital lifestyle.
Dual-core processor delivers high performance
Equipped with powerful yet energy efficient Freescale ARM dual-core processor, the TS-431 is a high-performance home NAS providing incredible performance. The TS-431's enhanced encryption and decryption performance provides transfer speeds of over 30 MB/s with AES-256 bit full NAS volume encryption, boosting system performance & security while ensuring the safety of sensitive personal data stored in the TS-431. You can also use the TS-431 as a home multimedia hub to enjoy your photo, music and videos while downloading or backing up files without impacting the TS-431's performance. -
High Efficiency with dual LAN support
The TS-431 supports multiple port-trunking modes, enabling IT administrators to set up link aggregation to increase total data transmission capability. Failover and dual IP are also supported to ensure continuous system operations. -
QTS - simple and efficient
Thanks to QTS intuitive user interface, system operations of the TS-431 are smooth and handy. Its intelligent desktop allows you to find desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater operating efficiency. -
Well-rounded backup solutions to secure data
By connecting external drives to the Turbo NAS via eSATA or USB, you can easily configure and copy shared folders on the TS-431 to external devices. The front panel USB port features a one-touch-copy function for you to instantly back up data on external drives to the TS-431 or alternatively to back up data from the TS-431 to external drives. QNAP's NetBak Replicator supports real-time and scheduled data backup for Windows and Mac OS X users can use Time Machine to effortlessly back up data to the TS-431. -
Cross-platform file sharing, centralized data storage
The TS-431 supports SMB/CIFS, NFS, and AFP protocols for file sharing across Windows, Mac and Linux/UNIX. Data, logs and ISO image of CDs and DVDs can be centrally stored in the TS-431 and protected by an integrated antivirus solution. -
Manage your files via the Internet
The file station brings conventional desktop-style file operations to web browsers, allowing you to upload, download, and manage files on your TS-431 wherever there is an internet connection. Supporting file extraction, folder creation, and smart search for files and folders, file station also allows you to easily share files with friends & family via unique URLs. With reliable security features, SSL and password options, managing & sharing your files is simple and safe with the file station. -
Build your home music library and enjoy music anywhere
The music station helps categorize your music collection, and displays album covers to easily organize your personal playlists. Through the music station web player, you can enjoy your music anytime, anywhere with a few clicks. Thousands of local and global online Internet radio programs are also built-into the music station for you to enjoy.
- QNAP TS-431+ - NAS server - 32 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 32 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 18 cm x 23.5 cm x 17.7 cm
- 3 kg ()
- Processor
- 1 x Annapurna Labs 1.4 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 4 x 8 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 25
- RAM
- 1 GB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.1
- System Requirements
- UNIX, Linux, Apple MacOS X or later, Microsoft Windows Server 2003 or later, Microsoft Windows 7 or later
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 32 TB
- 18 cm
- 23.5 cm
- 17.7 cm
- 3 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- RAM
- 1 GB DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 4 x 8 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Hardware encryption, trunking, LDAP support, wake on LAN (WOL), E-mail alert, print server, IPv6 support, antivirus analysis, 256-bit encryption, proxy server, backup server, download client, file sharing, Access Control List (ACL) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, NTP server, DHCP client, e-mail notification, VPN Server, Apple AirPlay
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- UPnP
Security DVR
- 25
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A , 1 x eSATA
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), audible alarm, built-in cooling fan, hardware encryption
- Security Slot Type
- Kensington security slot
- VCCI, C-Tick, BSMI, FCC
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Power Provided
- 90 Watt
- QNAP QTS 4.1
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
