QNAP TS-328 3 Bay Desktop NAS
Quicklinx: DGCGWS00 Mfr#: TS-328
Powered by a fast processor, the TS-328 features a minimalist design that easily fits into your home or commercial space. With a variety of multimedia applications, transcoding capabilities and cross-device file backup and synchronization, the TS-328 provides a highly cost-effective solution for storage, backup, file management, and sharing.
  • Central management for multimedia files
    You may have lots of photos or videos spread across devices, which can be hard to manage and back up. With the TS-328, you can centrally backup and manage all your files and easily share them with others.
  • Protect data with snapshots
    Snapshots help protect your data by fully recording the NAS system state and the metadata. If an error occurs, you can use snapshots to quickly restore the system to its normal state. QNAP snapshots are block-based and only record the changed data. Not only does this save storage space but also reduces the time required to back up and restore data.
  • Real-time video transcoding
    The TS-328 supports hardware decoding and real-time transcoding, allowing you to convert videos to universal file formats that can be smoothly played on multiple devices. Therefore, you can easily share movies or travel videos saved on your NAS to your family and friends via shared links and they can enjoy watching the videos smoothly anytime and anywhere.
QNAP TS-328 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 3 (max)
15 cm x 26.01 cm x 14 cm
1.64 kg ()
1 x Realtek Semiconductor Cortex-A53 1.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 5, JBOD
1GbE
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
15 cm
26.01 cm
14 cm
1.64 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB DDR4
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 5, JBOD
1GbE
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP, SMSC
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
DHCP support, dynamic DNS server, manageable, E-mail alert, print server, IPv6 support, IP address filtering, backup server, download client, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, DLNA Media Server, DHCP client, Apple AirPlay, Chromecast support
UPnP
Expansion Bays
3 (total) / 3 (free) x internal - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x audio in - mini-jack , 1 x audio out - mini-jack
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan
Security Slot Type
Kensington security slot
External power adapter
AC 120/230 V
18.35 Watt
Power Provided
65 Watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
Sound Emission
16.5 dBA
