QNAP TS-264-8G - NAS Server
Quicklinx: HQ2FWS00 Mfr#: TS-264-8G
  • Celeron
Hurry, only 1 left in stock!
£398.21 ex VAT
£477.85 inc VAT
Powered by an Intel Celeron N5105/N5095, quad-core processor (burst up to 2.9 GHz), the TS-264 features two 2.5GbE RJ45 ports and Port Trunking for up to 5Gbps combined bandwidth. With M.2 PCIe Gen3 and PCIe Gen 3 slots, the TS-264 provides flexibility in extending NAS functionality, allowing you to install a QM2 card for M.2 SSD caching, or Edge TPU for AI image recognition and various 10 GbE/5 GbE network cards. The TS-264 comes with 8 GB RAM for running light VMs and Containers, and supports multi-cloud backup, cloud storage gateways, 4K HDMI output and real-time transcoding, alongside expandable storage capacity and feature-rich apps to perform as a cost-efficient, reliable 2.5 GbE NAS.
  • 2.5GbE is a must
    TS-264 is as fast as a single-port 10GbE NAS with up to 589 MB/s transfer speeds by setting port trunking with the two built-in 2.5GbE (2.5G/1G/100M) ports.
  • Quad-core for multitasking
    Perform additional tasks, stream more media, and have more services running with an Intel quad-core processor optimized for multitasking.
  • Smooth video conversion
    Built-in GPU for enhanced video conversion, allowing videos to be smoothly streamed from the NAS to mobile devices.
  • Upgrade to dual-port 10GbE
    Futureproof your network connection by installing a PCIe dual-port 10GbE network card that delivers up to 1,644 MB/s transfer speed.
  • Faster USB transfer
    Two USB 3.2 Gen 2 (10Gbps) ports allow faster backup to/from USB devices.
  • More M.2 NVMe SSDs
    If two M.2 slots aren't enough, install a QM2 PCIe expansion card for more M.2 SSD slots.
QNAP TS-264 - NAS server
NAS server
Host Connectivity
2.5 Gigabit Ethernet
0 (installed) / 2 (max)
10.5 cm x 22.6 cm x 16.8 cm
1.55 kg ()
Czech, Chinese (traditional), Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Brazilian Portuguese, Romanian, Russian, Spanish, Swedish, Thai, Turkish
1 x Intel Celeron N5105/N5095 (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, 50, JBOD, 60
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Performance
Concurrent connections (CIFS): 1500 , Maximum number of storage pool: 128 , Maximum number of volume: 128 , Maximum volume size: 250 TB , Maximum pool size: 308 TB , Maximum shared folder size: 250 TB , Maximum number of shared folder: 512 , Maximum LUN size: 250 TB , Maximum number of targets LUN: 256 , Minimum snapshot interval: 5 min , Maximum FTP connection: 1024 , Local user account: 4096 , Local group account: 512 , Domain user/group account: 200000 , Virtual hosts: 32 , Log recording: 3000 events per second
RAM
8 GB
AC 100-240 V
Storage Operating System
QNAP QTS 5.0.1
Apple MacOS X 10.10 or later, Ubuntu Linux 14.4 (64-bit), CentOS 7.0, Red Hat Enterprise Linux 6.6, SuSE Linux 12 or later, IBM AIX 7, Microsoft Windows 7 / 8 / 10 / 11, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Oracle Solaris 10 or later
3-year warranty
NAS server
Host Connectivity
Total Storage Capacity
0 GB
10.5 cm
22.6 cm
16.8 cm
1.55 kg ()
Built-in Devices
Led panel, IR sensor
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.9 GHz
RAM
8 GB (installed) / 8 GB (supported)
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
Network / Transport Protocol
CIFS, iSCSI, QuFTP, IPv6, IPv4, DDNS, PPTP, L2TP, IPSec, WireGuard, QBelt, OpenVPN
Remote Management Protocol
TFTP, SNMP 2, SNMP 3, SSH, Telnet, HTTP, HTTPS, RADIUS
Network Services Compatibility
Apple File Protocol (AFP), Microsoft CIFS, FTP, Network File System v3 (NFS v3), Network File System v4 (NFS v4), SFTP, HTTP, HTTPS
Performance
Floating point unit, built-in hardware transcoding, SSD cache acceleration support, WOL, Jumbo Frames support, Storage Pool, SED Storage Pool, JBOD Expansion, VJBOD Cloud, iSCSI service, file-based iSCSI LUN, block-based iSCSI LUN, LUN masking, LUN mapping, WWPN Aliases Import/Export, FC Port Group, FC Port Binding, MPIO, online LUN capacity expansion, LUN snapshot, LUN snapshot replication and clone, auto tiering, RAID Group, RAID Level Migration, RAID Expansion, Storage Pool Expansion, RAID Hot Spare, RAID Sync/Rebuild/Scrubbing, Disk, Enclosure Locate, Disk S.M.A.R.T. Scan, Disk S.M.A.R.T. Data Migration, SSD trim, SSD life estimation, Disk Roaming, Disk Standby, Volume Snapshot, Snapshot Retention Policy, Self-serve Snapshot Recovery, Application Consisted Snapshot, Snapshot Full Clone, Snapshot Replica / Vault, SSD read-only Cache, SSD read-write cache, SSD write-only cache, SSD profiling tool, External Device Management, SSD Cache RAID, MTP, FTP server, FXP support, Object Storage, file station, domain security, Domain Controller, Windows ACL, user quota managerment, group quota, folder quota, home folder, Resource Monitor, Network Recycle Bin, schedule on/off, Virtual Switch, port trunking, VLAN support, DHCP server, security counselor, malware remover, 2-step verification, Allow/Deny List, Access Protection, Service binding, WebDAV server support, Qsync, HybridMount, hybrid backup sync, Hyper Data Protector, Boxafe, Qsirch, QuMagie, QVPN Service, antivirus analysis, LDAP server, HD Station, SQL Server, Qfiling, QmailAgent, QuWAN, DA Driver Analyzer, Q'center (NAS CMS)
Encryption Algorithm
AES-NI, SSL, TLS, 256-bit AES, FIPS 140-2, TLS 1.0, TLS 1.1, TLS 1.2, TLS 1.3
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x M.2 2280 , 1 (total) / 1 (free) x PCI Express 3.0 x2
2 x 2.5 Gigabit Ethernet - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.2 Gen 2 - Type A , 1 x HDMI output
1 x network cable
Reset button, on/off power switch, USB copy button, 70mm cooling fan, security lock slot (cable lock sold separately), Secure Erase, Smart Fan, built-in firewall
Security Slot Type
Kensington security slot
FIPS 140-2
Power cable, 6 x flat head screws (for 2.5" HDD), 6 x flat head screws (for 3.5" HDD)
External power adapter
AC 100-240 V
12.448 Watt
Power Provided
65 Watt
QNAP QTS 5.0.1
Software Included
IronWolf Health Management, vSphere plug-in for VMware, Windows Update Agent, McAfee AntiVirus, QNAP Virtualization Station
Limited warranty - 3 years
Shipping Weight
2.68 kg
5 - 95% RH (non-condensing)
Interface: Fast Ethernet
Capacity: 0GB
Interface: Ethernet
Interface: Gigabit Ethernet
Interface: 2.5 Gigabit Ethernet
Brand: QNAP
