QNAP TS-262-4G 2 Bay Desktop NAS
Quicklinx: HQ2GWS00 Mfr#: TS-262-4G
  • Celeron
£254.42 ex VAT
£305.30 inc VAT
A fast and vast private cloud storage with a range of multimedia and file management applications, the TS-262 is ideal for home users to maximize their digital lifestyle. Files, data and multimedia saved on the TS-262 can be accessed from all your connected devices, including phones, computers and smart TVs. A 2.5GbE port and HDMI 2.0 port come as standard, allowing you to enjoy lag-free multimedia streaming throughout your home and directly on your TV. The TS-262 can be geared up to fit future needs, supporting two M.2 PCIe slots for Qtier auto-tiering storage technology, and can be easily expanded to fit growing data needs. The TS-262 also supports Edge TPU, allowing you to easily organize your photos based on facial and object recognition with the QuMagie app.
  • 2.5GbE port
    Immediately multiply your network speed by 2.5 times while using existing CAT5e cables.
  • HDMI port
    4K media playback and real-time transcoding; directly watch videos using HDMI (4K @ 60 Hz) output.
  • PCIe slot
    Install a PCIe Gen3 x2 card to expand the core functionality of the TS-262, including a Multi-Gig 10GbE/5GbE network card, a USB 3.2 Gen 2 (10 Gbps) card, or a Wi-Fi 6 network card.
  • Expand storage capacity
    Flexibly scale your total storage capacity by connecting USB expansion enclosures (please see the compatibility list).
QNAP TS-262 - NAS server
NAS server
Host Connectivity
2.5 Gigabit Ethernet
0 (installed) / 2 (max)
10.5 cm x 22.6 cm x 16.8 cm
1.55 kg ()
Czech, Chinese (traditional), Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Brazilian Portuguese, Romanian, Russian, Spanish, Swedish, Thai, Turkish
1 x Intel Celeron N4505 (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, 50, JBOD, 60
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Performance
Concurrent connections (CIFS): 1500 , Maximum number of storage pool: 128 , Maximum number of volume: 128 , Maximum volume size: 250 TB , Maximum pool size: 308 TB , Maximum shared folder size: 250 TB , Maximum number of shared folder: 512 , Maximum LUN size: 250 TB , Maximum number of targets LUN: 256 , Minimum snapshot interval: 5 min , Maximum FTP connection: 1024 , Local user account: 4096 , Local group account: 512 , Domain user/group account: 200000 , Virtual hosts: 32 , Log recording: 3000 events per second
RAM
4 GB
AC 100-240 V
Storage Operating System
QNAP QTS 5.0.1
Apple MacOS X 10.10 or later, Ubuntu Linux 14.4 (64-bit), CentOS 7.0, Red Hat Enterprise Linux 6.6, SuSE Linux 12 or later, IBM AIX 7, Microsoft Windows 7 / 8 / 10 / 11, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Oracle Solaris 10 or later
NAS server
Host Connectivity
Total Storage Capacity
0 GB
10.5 cm
22.6 cm
16.8 cm
1.55 kg ()
Built-in Devices
Led panel, IR sensor
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
Max Turbo Speed
2.9 GHz
RAM
4 GB (installed) / 4 GB (supported)
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
Network / Transport Protocol
CIFS, iSCSI, QuFTP, IPv6, IPv4, DDNS, PPTP, L2TP, IPSec, WireGuard, QBelt, OpenVPN
Remote Management Protocol
TFTP, SNMP 2, SNMP 3, SSH, Telnet, HTTP, HTTPS, RADIUS
Network Services Compatibility
Apple File Protocol (AFP), Microsoft CIFS, FTP, Network File System v3 (NFS v3), Network File System v4 (NFS v4), SFTP, HTTP, HTTPS
Performance
Floating point unit, built-in hardware transcoding, SSD cache acceleration support, wake on LAN (WOL), Jumbo Frames support, Storage Pool, SED Storage Pool, JBOD Expansion, VJBOD Cloud, iSCSI service, file-based iSCSI LUN, block-based iSCSI LUN, LUN masking, LUN mapping, WWPN Aliases Import/Export, FC Port Group, FC Port Binding, multipath IO (MPIO), online LUN capacity expansion, LUN snapshot, LUN snapshot replication and clone, auto tiering, RAID Group, RAID Level Migration, RAID Expansion, Storage Pool Expansion, RAID Hot Spare, RAID Sync/Rebuild/Scrubbing, Disk, Enclosure Locate, Disk S.M.A.R.T. Scan, Disk S.M.A.R.T. Data Migration, SSD trim, SSD life estimation, Disk Roaming, Disk Standby, Volume Snapshot, Snapshot Retention Policy, Self-serve Snapshot Recovery, Application Consisted Snapshot, Snapshot Full Clone, Snapshot Replica / Vault, SSD read-only Cache, SSD read-write cache, SSD write-only cache, SSD profiling tool, External Device Management, SSD Cache RAID, Mount Smart Phone (MTP), FTP server, FXP support, Object Storage, file station, domain security, Domain Controller, Windows ACL, user quota managerment, group quota, folder quota, home folder, Resource Monitor, Network Recycle Bin, schedule on/off, Virtual Switch, port trunking, VLAN support, DHCP server, security counselor, malware remover, 2-step verification, Allow/Deny List, Access Protection, Service binding, WebDAV server support, Qsync, HybridMount, hybrid backup sync, Hyper Data Protector, Boxafe, Qsirch, QuMagie, QVPN Service, antivirus analysis, LDAP server, HD Station, SQL Server, Qfiling, QmailAgent, QuWAN, DA Driver Analyzer, Q'center (NAS CMS)
Encryption Algorithm
AES-NI, SSL, TLS, 256-bit AES, FIPS 140-2, TLS 1.0, TLS 1.1, TLS 1.2, TLS 1.3
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x M.2 2280 , 1 (total) / 1 (free) x PCI Express 3.0 x2
1 x 2.5 Gigabit Ethernet - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.2 Gen 2 - Type A , 1 x HDMI output
1 x network cable
Reset button, on/off power switch, USB copy button, 70mm cooling fan, security lock slot (cable lock sold separately), Secure Erase, Smart Fan, built-in firewall
Security Slot Type
Kensington security slot
FIPS 140-2
Power cable, 6 x flat head screws (for 2.5" HDD), 6 x flat head screws (for 3.5" HDD)
External power adapter
AC 100-240 V
12.448 Watt
Power Provided
65 Watt
QNAP QTS 5.0.1
Software Included
IronWolf Health Management, vSphere plug-in for VMware, Windows Update Agent, McAfee AntiVirus, QNAP Virtualization Station
Shipping Weight
2.68 kg
5 - 95% RH (non-condensing)
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Capacity: 0GB
Interface: 2.5 Gigabit Ethernet
Brand: QNAP
