The TS-253Be features a simple physical design that can easily fit into office and home environments. It provides a PCIe port that can boost its functionality: a QNAP QM2 expansion card can be installed to add M.2 SSD caching/10GbE connectivity and support for Qtier auto-tiering technology, or a compatible wireless card can be installed to use the TS-253Be as a wireless access point. The TS-253Be also supports dual-channel 4K H.264/H.265 processing to provide a smooth media viewing experience on all connected devices. In addition, a wide range of productivity tools are available for use on the TS-253Be to improve work efficiency for media creators or creative professionals, while also enriching their multimedia experience.
Extend NAS functionalities with the PCIe slot
With PCIe expansion, the TS-253Be provides flexibility in extending NAS functionality and potential applications. Install a QNAP QM2 card to provide M.2 SSD caching/10GbE connectivity, or use the TS-253Be as a wireless access point by installing a compatible wireless network card (ex. QNAP QWA-AC2600), or boost the USB connectivity of the TS-253Be by installing a USB 3.1 10Gbps card.
Real-time video transcoding
Featuring advanced 9th-generation IntelĀ® HD Graphics, the TS-253Be supports dual-channel 4K H.264/H.265 hardware decoding and real-time transcoding, allowing you to convert videos to universal file formats that can be smoothly played on multiple devices. Therefore, you can easily share movies and videos stored on your NAS with family and friends for their enjoyment on a range of devices.
Robust security
Equipped with 256-bit AES, AES-NI, FIPS 140-2, and SSL encryption algorithms, this NAS server ensures your data is protected with high-level security measures. -
High connectivity
Featuring two Ethernet 1000Base-T ports, five USB 3.0 ports, and dual HDMI outputs, the TS-253Be-2G offers versatile connectivity options for a wide range of devices. -
Advanced networking
Supports a variety of networking protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, along with DHCP server/client capabilities, VPN Server and client, and Wake On LAN (WOL), providing flexible and efficient network management. -
Efficient storage management
With support for RAID 0, RAID 1, and JBOD, the device offers flexible storage options, allowing you to optimize performance and redundancy according to your needs. -
Comprehensive media support
DLNA CERTIFIED with 4K resolution support and equipped with an iTunes server, FTP server, and DLNA Media Server, this NAS server is an ideal solution for streaming and sharing your media content across devices.
- QNAP TS-253Be-2G - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 10.5 cm x 22.6 cm x 16.8 cm
- 1.66 kg ()
- Processor
- 1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID 0, 1, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 2 GB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP QTS 4.3.4
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 10.5 cm
- 22.6 cm
- 16.8 cm
- 1.66 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.3 GHz
- RAM
- 2 GB (installed) / 8 GB (supported) - DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, FTP, DHCP, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- WOL, iTunes server, Jumbo Frames support, DHCP server, FTP server, teaming support, DLNA Media Server, DHCP client, 4K resolution support, VPN Server, VPN client, port trunking, FXP support, RTRR server, RTRR client
- Encryption Algorithm
- SSL, FIPS 140-2, 256-bit AES, AES-NI
- DLNA CERTIFIED
Security DVR
- Compression Format
- H.264, H.265
- Expansion Bays
- 2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express 2.0 x2
- 2 x Ethernet 1000Base-T - RJ-45 , 5 x USB 3.0 - Type A , 2 x microphone - mini-jack , 2 x HDMI output - Type A , 1 x audio out - mini-jack
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan
- Security Slot Type
- Kensington security slot
- Included Accessories
- Screws
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 20.42 Watt
- Power Provided
- 65 Watt
- QNAP QTS 4.3.4
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
