In response to the coming era of Internet of Things (IoT), the TS-253A innovatively supports the open-source Linux platform as a gateway for IoT solutions to other smart devices. The TS-253A allows users to directly utilize various feature-rich Linux apps, enjoying a private cloud combining storage and IoT applications, and professional developers can develop and run IoT applications directly on the TS-253A. The secure, reliable TS-253A is packed with business-critical features such as Volume/LUN Snapshot - allowing files/folders to revert to a previous state in case of any corruption or file-loss. The TS-253A is powered by the latest quad-core Intel Celeron processor which allows users to enjoy 4K (H.264) video playback and 1080p/4K video real-time transcoding directly from the TS-253A to an HD/4K display.
- QNAP TS-253A - NAS server - 8 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 10.2 cm
- 21.6 cm
- 15 cm
- 1.74 kg
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- 1 x Intel Celeron N3150 1.6 GHz
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB (installed) / 8 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 2 x 4 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Buffer Size
- 64 MB
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, video server, 256-bit encryption, firmware upgradable, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR)
- Encryption Algorithm
- SSL, TLS, FIPS 140-2, 256-bit AES
- DLNA CERTIFIED, UPnP
Security DVR
- IP Cameras Supported
- 40
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 0 (free) x SO-DIMM 204-pin
- 2 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x microphone - 6.3mm jack , 2 x HDMI output , 1 x audio out - mini-jack
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), audible alarm, remote control, built-in cooling fan
- FIPS 140-2
- Included Accessories
- Remote control
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 14.43 Watt
- Power Provided
- 65 Watt
- Storage Operating System
- QNAP QTS 4.2
- OS Required
- UNIX, Linux, Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
