QNAP TS-251+-2G/8TB-RED 2 Bay Desktop NAS
Quicklinx: BY9WWS00 Mfr#: TS-251+-2G/8TB-RED
Capacity: 8TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Celeron
  • Windows 8 (32/64 bits)
13 in stock
£467.62 ex VAT
£561.14 inc VAT
Facing the increasing demand for data storage, sharing and multimedia processing, more and more users are looking for a NAS system with good performance and an affordable price tag. The Intel quad-core TS-251+ provides an uncompromising high-performance scalable storage solution for professional users. Powered by the intelligent QTS 4.2 operating system, the TS-251+ performs as an easy-to-use yet powerful NAS for data backup, file synchronization and sharing, remote access and multimedia applications, and is ideal for users to create a secure private cloud to access their data easily.
QNAP TS-251+ - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
8 TB
2 (installed) / 2 (max)
10.2 cm x 22.5 cm x 16.85 cm
1 x Intel Celeron 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 4 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Gigabit Ethernet
8 TB
10.2 cm
22.5 cm
16.85 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 4 TB
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR)
Encryption Algorithm
SSL, TLS, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
40
Expansion Bays
2 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x HDMI output
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, remote control, built-in cooling fan
Security Slot Type
Kensington security slot
Remote control
External power adapter
AC 120/230 V
Power Provided
60 Watt
QNAP QTS 4.2
5 - 95% (non-condensing)
Capacity: 8TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: QNAP
Price Range Ex VAT: 300 - 500
