QNAP TS-231P2-1G 2 Bay Desktop NAS
Quicklinx: D88DWS00 Mfr#: TS-231P2-1G
The TS-231P is a powerful yet easy-to-use network storage center for backup, synchronization, remote access and home entertainment. The powerful TS-231P features USB 3.0 ports and dual LAN ports, delivering outstanding multitasking performance to enhance your productivity and digital life and offering an ideal storage and backup center as a secure private cloud.
  • Powerful processor delivers high performance
    Equipped with an excellent processor and generous memory, the TS-231P is a high-performance NAS for home, workgroups and SOHO users, providing outstanding performance. The TS-231P's enhanced hardware-based encryption and decryption engine provides fast transfer speeds with AES 256-bit full NAS volume encryption, boosting system performance and security, while ensuring the safety of sensitive personal data, stored in the NAS. When used with a compatible 802.11ac or dual-band USB Wi-Fi adapter, the TS-231P becomes an ideal media center with remarkably high speeds for transferring a large amount of files and streaming bandwidth-intensive multimedia.
  • High efficiency with dual LAN support
    The TS-231P supports multiple port-trunking modes, enabling administrators to set up link aggregation to increase total data transmission potential. Failover and dual IP are also supported to ensure continuous system operations.
  • Enhance productivity with multiple USB 3.0 ports
    Equipped with SuperSpeed USB 3.0 ports, the TS-231P allows you to flexibly arrange tasks with a wide range of external devices without interrupting your current workflow. You can back up files to USB drives, access data stored on SD cards via USB card readers, share printers via network and connect to a UPS to ensure a continual power supply.
  • Well-rounded backup solutions to secure data
    The TS-231P is a comprehensive centralized backup center for multiple files. The front panel USB port features a one-touch-copy function for you to instantly back up data on USB drives to the TS-231P or alternatively to back up data from the TS-231P to USB drives.
  • Energy-saving design
    The TS-231P features an energy-efficient processor, that maintains high performance in system operations and is suitable for an always-online personal cloud without running up a high electricity bill. Additional energy-saving features combine hard disk standby, scheduled power on/off, and Wake on LAN.
QNAP TS-231P2 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 2 (max)
10.2 cm x 21.9 cm x 16.9 cm
1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
25
RAM
1 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
10.2 cm
21.9 cm
16.9 cm
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
1 GB (installed) / 8 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Trunking, LDAP support, WOL, Syslog support, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, download client, file sharing, event log, TFTP support, ACL support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SFTP client, Apple AirPlay, Dropbox support, Wi-Fi USB dongle support, RTRR, Google Drive support, Amazon Cloud Drive support, Yandex Disk support, Microsoft OneDrive support
Encryption Algorithm
SSL, TLS, 256-bit AES
UPnP
Security DVR
25
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, built-in cooling fan, hardware encryption, scheduled power on/off
Security Slot Type
Kensington security slot
AES-256
External power adapter
AC 120/230 V
Power Provided
65 watt
QNAP QTS 4.3
5 - 95% (non-condensing)
Sound Emission
19.5 dBA
