QNAP TS-228 2 Bay NAS
Quicklinx: C8F1WS00 Mfr#: TS-228
The TS-228 is a lightweight, easy to use and feature-rich networked storage center for backup, synchronization, remote access, and home entertainment. It’s energy-efficient and budget-friendly, ideal for home users to start their personal cloud and stay connected to files with full control. See how TS-228 can make your digital life easier, simpler and more convenient.
  • Organize your content and backups in one centralized location
  • Synchronize files between computers, tablets, and mobile devices
  • Collect, enjoy, and share your large photo, music, and video collection
  • Stream your multimedia library via DLNA to other devices and your TV
  • Access, manage and enjoy all your files with your tablets and smartphones
  • Enjoy the App Center with hundreds of install-on-demand apps to increase diverse applications
  • Dual-core processor for high performance
    Powered by an ARM v7 1.1 GHz dual-core processor with 1 GB DDR3 RAM, the TS-228 delivers an average of 112 MB/s reading and 81 MB/s writing speed for smooth data transmission, concurrent access from multiple users, and home applications. The high-performance and capable TS-228 is ideal for serving as a multimedia center as you can back up or download files without impacting the TS-228's performance.
  • Light, handy, and tool-less design
    The TS-228 features a mini-tower design that takes less desktop space, making it suitable for homes and small/home offices. Compared with a traditional NAS cooling fan, the TS-228 houses a compact and quiet exhaust that helps dissipate heat with less noise and dust. With the tool-less design, you can easily remove the TS-228's side cover to add or replace hard drives. The TS-228 is a light, handy and functional NAS that fits snugly into your digital lifestyle.
  • Comprehensive security options
    In open network environments, data on the connected devices may be exposed in a potential hack. The TS-228 provides numerous security options, such as 2-step verification, encrypted access, IP blocking, antivirus, and more. Administrators can also control the access rights of each user to different folders, preventing unauthorized access to important files. The TS-228 can secure access as being a VPN Server & VPN Client, and also supports setting up a proxy server to ensure connectivity safety.
  • Energy-saving design
    The TS-228 features an energy-efficient dual-core ARM processor that maintains high performance in system operations and is suitable for an always-online personal cloud without running up a high electricity bill.
QNAP TS-228 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 2 (max)
9 cm x 12.5 cm x 18.77 cm
0.7 kg ()
1 x ARM7 1.1 GHz
Storage Controller
SATA SATA 3Gb/s
GigE
RAM
1 GB
AC 120/230 V
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows 2000 / XP, Microsoft Windows 2003, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
9 cm
12.5 cm
18.77 cm
0.7 kg ()
Processor / Memory
Processors Installed
1 x ARM7 1.1 GHz
Max Supported Qty
1
RAM
1 GB DDR3
Flash Memory Installed
4 GB
Storage Controller
SATA
Interface Type
SATA 3Gb/s
GigE
Network / Transport Protocol
TCP/IP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
DHCP support, trunking, Syslog support, dynamic DNS server, manageable, E-mail alert, print server, IPv6 support, IP address filtering, firmware upgradable, MySQL server, web server, backup server, event log, SSH support, iTunes server, Jumbo Frames support, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support
IEEE 802.3ad (LACP), UPnP
Expansion Bays
2 (total) / 2 (free) x internal - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 1 x USB 3.0 - Type A
1 x network cable
External power adapter
AC 120/230 V
13.24 Watt
Power Provided
36 Watt
QNAP QTS 4.2
5 - 95% (non-condensing)
