The TS-212P is a powerful yet easy to use network storage center for data storage, backup, synchronization, remote access, and home entertainment. As your personal cloud, you will always be connected to your files and your files are always under your control.
The TS-212P is high-performance cross-platform storage with many friendly storage and backup options that centralizes and protects all your important files on one single device.
The TS-212P acts as your photo vault for you to back up your favorite photos. The Photo Station makes photo sharing simple, and you can designate your own access right controls. Simply upload your photos to the TS-212P to create and organize your photo albums through a web browser to share with your family and friends. Your mobile devices are useful too, with the Qfile mobile app in your iOS or Android devices you can instantly upload photos to the TS-212P.
- QNAP TS-212P Turbo NAS - NAS server - 4 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 8.5 cm x 21.84 cm x 16.55 cm
- Processor
- Marvell 88F6282 1.6 GHz
- Storage Controller
- RAID SATA 3Gb/s - RAID 0, 1, JBOD
- Hard Drive
- 2 x 2 TB
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE
- RAM
- 512 MB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP Turbo NAS System 4.0
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 4 TB
- 8.5 cm
- 21.84 cm
- 16.55 cm
Processor / Memory
- Processors Installed
- RAM
- 512 MB DDR3
- Flash Memory Installed
- 16 MB
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - 3.5"
- Capacity
- 2 x 2 TB
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- TCP/IP, iSCSI, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, SSH
- Network Services Compatibility
- Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- DHCP support, trunking, E-mail alert, print server, IPv6 support, IP address filtering, firmware upgradable, MySQL server, web server, backup server, file sharing, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, Apple Time Machine compatible
- UPnP
- Expansion Bays
- 2 (total) / 0 (free) x internal - 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
- Cables Included
- 1 x network cable , 1 x Serial ATA cable , 1 x Serial ATA power adapter
- K-lock security slot, LED indicator, built-in cooling fan
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 13 Watt
- Power Provided
- 60 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 0 °C
- 40 °C
- 0 - 95%
