The TS-212P is a powerful yet easy to use networked storage center for backup, synchronization, remote access, and home entertainment. As your personal cloud, you will always be connected to your files and your files are always under your control. See how TS-212P featuring the QTS 4.0 can make your digital life easier, simpler and more convenient.
Easy system setup on start.qnap.com
The TS-212P provides system installation without using a CD. Simply visit the setup portal start.qnap.com and follow the setup guide to complete the system setup and download the utilities you want. For beginners, the TS-212P features an "Auto Setup" option to provide an easy way to set up the TS-212P with recommended settings. All settings can be flexibly changed at a later time after the installation. -
Intuitive operation with zero learning
The TS-212P features the brand new QTS Turbo NAS operating system. The familiar multi-window design and multi-tasking design ability effectively increases operation efficiency. The intelligent desktop provides numerous innovative features, including Main Menu, graphic Dashboard, drag-and-drop icons, multiple desktops, personalized wallpapers, and the smart Toolbar. It requires virtually no learning to get started. -
A private cloud without constraints
In contrast to the limited storage space and security concerns of public cloud services, the TS-212P is advantageous for establishing a secure and large-capacity private cloud. myQNAPcloud service allows remote access to the TS-212P from anywhere. You can easily get access to the TS-212P, instantly share multimedia contents and check the system status via the Internet whether you are on the bus or in a coffee shop. -
Dropbox-like file sync across devices
Is Dropbox not enough to satisfy your storage needs? With Qsync, your TS-212P is turned into a safe data center for file synchronization. Every file uploaded to the TS-212P will be made available for all linked devices including computers, laptops and mobile devices. Qsync is especially useful for frequent travelers as it ensures the most up-to-date files are accessible on all linked devices. Qsync provides multiple ways of file synchronization and group file sharing, greatly enhancing the flexibility of team projects and collaboration. -
Access, sync and share on your mobile devices
The TS-212P is your private cloud storage that virtually enlarges the capacity of your smart mobile devices. Qfile allows you to access, upload, download, manage, and share stored files easily as if you are carrying tons of files in your pocket. The Qfile app for iOS also allows users to browse videos and photos stored on the TS-212P and play on the TV via AirPlay. Qmanager lets you monitor and manage the TS-212P remotely and efficiently without turning on a PC. -
Build your home music library and enjoy music anywhere
The Music Station helps categorize your music collection, and displays album covers to easily organize your personal playlists. Through the music station web player, you can enjoy your music anytime, anywhere with a few clicks. Thousands of local and global online Internet radio programs are also built-into the Music Station for you to enjoy. -
Turn your living room into a movie theater
Being DLNA compliant, you can view photos, play videos, and listen to music on the TS-212P on any DLNA devices, such as HDTVs, video game consoles, Hi-Fi systems, and even stream Internet radio stations from all over the world. The TS-212P combines smart TV and Hi-Fi systems perfectly to provide you with the utmost multimedia experience. -
Watch, record, and play digital TV programs
The Digital TV Station extends your multimedia experience to digital TV programs. Insert the DVB-T USB TV tuner to the TS-212P, and then you can log on to the Digital TV Station web interface to watch or record digital TV shows. The over-the-air EPG (Electronic Program Guide) is available for scheduled recordings. Just set recording schedules, sit back, and enjoy the shows on your computer whenever it's convenient. -
A surveillance solution with 24/7 security
The Surveillance Station turns the TS-212P into a professional surveillance solution with the user-friendly management interface, a wide range of compatible IP camera models, and expandable IP camera channel licenses. It also supports real-time monitoring, recording & playback with a wide range of customizable settings, and with the Vmobile app on your iOS or Android devices you can manage the monitoring of cameras anytime, anywhere, for total surveillance of your monitored environment. -
Well-rounded backup solutions to secure data
QNAP Netbak Replicator supports real-time and scheduled data backup on Windows including Outlook email archiving. Apple Time Machine is also supported to provide Mac OS X users with an effortless solution to back up data to the TS-212P. A wide range of third-party backup software such as Acronis True Image and Symantec Backup Exec are also supported. -
Excellent performance for multimedia entertainment
The TS-212P is an 2-bay model for home and small offices. Featuring a powerful processor, the TS-212P delivers excellent performance in file storage, multimedia applications and serving concurrent tasks at the same time. The TS-212P provides 2 X USB 3.0 ports which enable speedy data backup to external storage devices.
- QNAP TS-212P - NAS server - 16 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 16 TB
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 8.5 cm x 21.84 cm x 16.55 cm
- Processor
- 1 x Marvell 88F6282 1.6 GHz
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 8 TB
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 2700
- RAM
- 512 MB
- Power
- AC 120/230 V
- Storage Operating System
- QNAP Turbo NAS System 4.0
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits)
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 16 TB
- 8.5 cm
- 21.84 cm
- 16.55 cm
Processor / Memory
- Processors Installed
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
- Flash Memory Installed
- 16 MB
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 8 TB
- Data Link Protocol
- TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, PAP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, LDAP support, wake on LAN (WOL), Syslog support, dynamic DNS server, manageable, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, RADIUS support, SSH support, iTunes server, DHCP server, FTP server, SMS alert, BitTorrent Client, IPv4 support, surveillance station, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client
- UPnP
Security DVR
- 2700
- Expansion Bays
- 2 (total) / 0 (free) x internal - 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
- Cables Included
- 1 x network cable , 1 x Serial ATA cable , 1 x Serial ATA power adapter
- Security lock slot (cable lock sold separately), audible alarm, LED indicator, built-in cooling fan
- Security Slot Type
- Kensington security slot
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 13 Watt
- Power Provided
- 60 Watt
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
