QNAP TS-1635AX-4GB 16 Bay Desktop NAS
Quicklinx: DM9KWS00 Mfr#: TS-1635AX-4G
The TS-1635AX is powered by a Marvell ARMADA 8040 ARMv8 Cortex-A72 64-bit quad-core 1.6 GHz processor that provides tremendous computing power and is capable of running a range of applications to help businesses grow as their data increases. The TS-1635AX features twelve 3.5-inch drive bays, four 2.5-inch drive bays and two M.2 SATA slots for building a high-capacity and high-performance storage solution with optimal cost efficiency. The TS-1635AX is also equipped with two 10GbE SFP+ ports and two gigabit ports, providing high-speed connectivity and versatile networking possibilities. The TS-1635AX also allows hardware expansion with two PCI Express (PCIe) 3.0 slots, enabling more functionality by adding a QM2 M.2 SSD/10GbE card, QWA-AC2600 wireless network card and/or USB 3.1 Gen2 (10Gbps) card. The TS-1635AX offers high-capacity storage potential, high processing power, and high versatility for expansion, which all contribute to a next-gen storage system at a lowered total cost of ownership (TCO).
  • Robust security
    Equipped with 256-bit AES, SSL, and TLS encryption algorithms, the TS-1635AX ensures your data remains secure and protected against unauthorized access. Its Kensington security slot also provides physical security to prevent theft or tampering.
  • High-speed connectivity
    With dual 10Gb Ethernet SFP+ and dual Gigabit Ethernet ports, the TS-1635AX offers versatile, high-speed network connectivity options, enabling efficient data transfer and streaming capabilities.
  • Expansive storage options
    Featuring 16 supported devices/modules and hot-swap capabilities for 12 bays, the TS-1635AX provides flexible and scalable storage solutions, accommodating a wide range of data storage needs.
  • Advanced cooling system
    Built-in with 3 cooling fans, the TS-1635AX is designed to maintain optimal operating temperatures, ensuring reliable performance and longevity of the device even under heavy workloads.
  • Comprehensive network services
    Supporting a variety of network protocols and services including Apple AirPlay, BitTorrent Client, and cloud backup options, the TS-1635AX is a versatile NAS server that meets the demands of diverse networking environments.
QNAP TS-1635AX - NAS server
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
0 (installed) / 16 (max)
36.989 cm x 31.98 cm x 30.384 cm
12.06 kg ()
1 x Marvell ARMADA 1.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, 50, JBOD, 60
10Mb LAN, 100Mb LAN, 1GbE, 10GbE
RAM
4 GB
Storage Operating System
QNAP QTS 4.3.4
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10, Microsoft Windows Server 2016
NAS server
Host Connectivity
Total Storage Capacity
0 GB
36.989 cm
31.98 cm
30.384 cm
12.06 kg ()
Built-in Devices
Speaker, status LCD
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Hardware encryption, LDAP support, WOL, Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, download client, TFTP support, ACL support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, IPv4 support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, Apple AirPlay, Dropbox support, RTRR, Google Drive support, VPN client
Encryption Algorithm
SSL, TLS, 256-bit AES
DLNA CERTIFIED, UPnP
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" , 4 (total) / 4 (free) - 2.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x2 , 1 (total) / 1 (free) x PCI Express 3.0 x1 , 2 (total) / 2 (free) x M.2
2 x Ethernet 10Gb - SFP+ , 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.1 Gen 1 - Type A
2 x network cable
Security lock slot (cable lock sold separately), built-in 3 cooling fans, AirPlay
Security Slot Type
Internal power supply
Power Provided
250 watt
QNAP QTS 4.3.4
5 - 95% (non-condensing)
Sound Emission
23 dBA
