QNAP TS-131K - NAS server - SATA 6Gb/s - RAM 1 GB - Gigabit Ethernet
Quicklinx: G8YPWS00 Mfr#: TS-131K
Powered by quad-core 1.7 GHz processor, the TS-131K provides 1 drive bays storage space to securely store your important files and data, while allowing you to easily share files with family and friends. Featuring a compact pure white minimalist design, the TS-131K can easily integrate with any home décor and takes up very little space. The TS-131K comes with lockable drive trays, ensuring the drives will not be accidentally removed or fall out and cause data loss. The TS-131K provides comprehensive local, off-site and cloud backup and secure Snapshot technology to help create a reliable backup and disaster recovery plan. In the event of a system crash or accidental file deletion, you can quickly restore the system to its normal state.
NAS server
Host Connectivity
Gigabit Ethernet
0
7.3 cm x 21.9 cm x 16.1 cm
1.16 kg ()
1 x Annapurna Labs Alpine AL-214 1.7 GHz (Quad-Core)
Storage Controller
SATA SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
25
RAM
1 GB
AC 120/230 V
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
0
7.3 cm
21.9 cm
16.1 cm
1.16 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
1 GB (installed) / 1 GB (supported) - DDR3L
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Backup server, reset button, surveillance station, Apple Time Machine compatible, Apple AirPlay, Dropbox support, anti-virus protection, Photo album server, Google Drive support, built-in hardware transcoding, built-in streaming server, Microsoft OneDrive support, DLNA support, Chromecast support, file station, Qcontactz, Qsync
Encryption Algorithm
256-bit AES
Security DVR
25
Expansion Bays
1 (total) / 1 (free) x hot-swap - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.2 Gen 1 - Type A
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, reset button
Security Slot Type
Kensington security slot
AES-256
2 x hard drive security key, flat head screws (for 2.5" HDD), flat head screws (for 3.5" HDD), power cable
External power adapter
AC 120/230 V
Power Provided
36 watt
