QNAP TS-1263U-4G/48TB-RED PRO 12 Bay Rackmount NAS
Quicklinx: C2X2WS00 Mfr#: TS-1263U-4G/48TB-RED PRO
  • Windows 8 (32/64 bits)
The TS-1263U-RP is a powerful network storage system powered by a high-performance AMD quad-core processor. It uniquely provides 10GbE at a budget price to maximize ROI, and doubles the encrypted file transfer performance with the AES-NI hardware-accelerated encryption engine to over 800 MB/s. Powered by the QTS operating system, the TS-1263U-RP provides versatile all-in-one server functionalities as well as unique features including Virtualization Station, which allows users to run VMs on the same device. The TS-1263U-RP is designed for small and medium-sized businesses looking for backup, restoration, private cloud, storage for virtualization, and to future-proof their IT infrastructure for 10GbE networks.
QNAP TS-1263U Turbo NAS - NAS server - 48 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10Gbps SFP+
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
48 TB
12 (installed) / 12 (max)
48.2 cm x 53.4 cm x 8.9 cm
1 x AMD G-Series 2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10
Hard Drive
12 x 4 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
4 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 2U
48 TB
48.2 cm
53.4 cm
8.9 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 16 GB (supported) - DDR3L
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Hard Drive
HDD - hot-swap - 3.5"
12 x 4 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support
Encryption Algorithm
SSL, TLS, 256-bit AES
UPnP
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCI Express 2.0
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x Ethernet 10Gb - SFP+
2 x network cable
Audible alarm, built-in 2 cooling fans, scheduled power on/off
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.2
5 - 95%
