The TS-1263U is a powerful network storage system powered by a high-performance AMD quad-core processor. It uniquely provides 10GbE at a budget price to maximize ROI, and doubles the encrypted file transfer performance with the AES-NI hardware-accelerated encryption engine to over 800 MB/s. Powered by the QTS operating system, the TS-1263U provides versatile all-in-one server functionalities as well as unique features including Virtualization Station, which allows users to run VMs on the same device. The TS-1263U is designed for small and medium-sized businesses looking for backup, restoration, private cloud, storage for virtualization, and to future-proof their IT infrastructure for 10GbE networks.
Speedy transfer and hardware-accelerated encryption with AES-NI
The TS-1263U is a powerful NAS that delivers up to 1,059 MB/s sequential read throughput with one 10GbE configuration. The TS-1263U's hardware-accelerated encryption engine provides unmatched encryption performance in its class, up to 822 MB/s with AES-256 bit full NAS volume encryption, boosting system performance & security while ensuring the safety of sensitive business data stored in the TS-1263U. -
Built-in 10GbE connectivity
The TS-1263U supports 10 Gigabit high-speed networks with an included single-port SFP+ 10GbE network adapter in addition to the default 2 Gigabit Ethernet ports. The SFP+ 10GbE network adaptor can be replaced with a 10GBASE-T or a 2-port 10GbE adapter for the maximum flexibility. The 10GbE-ready TS-1263U delivers lightning-fast data throughput for businesses that demand higher bandwidth for virtualization and fast backup and restoration for an ever-growing amount of data. Coupled with its large storage capacity potential, the TS-1263U is perfect for companies to store massive data and excel in fast data transmission. -
High reliability design ensuring business continuity
The business-ready TS-1263U is designed to provide 24/7 operations and services. The support for comprehensive RAID configurations and hot-swapping allow for replacing hard drives without service interruption. QNAP's advanced RAID recovery technology also helps if any healthy drives are accidentally removed from a degraded RAID volume. The system can be recovered by reinserting the wrongly-removed hard drives so the data can still be accessible. The TS-1263U delivers high reliability and efficiency with quad LAN support for multiple port-trunking modes including fail-over support.
- QNAP TS-1263U - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10Gbps SFP+
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- 48.2 cm x 53.4 cm x 8.9 cm
- 16.14 kg ()
- Processor
- 1 x AMD G-Series 2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.2
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 48.2 cm
- 53.4 cm
- 8.9 cm
- 16.14 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 16 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
- Data Link Protocol
- TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, print server, IPv6 support, backup server, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, iTunes server, Jumbo Frames support, DHCP server, FTP server, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, cloud backup, VPN Server, SFTP client
- Encryption Algorithm
- SSL, 256-bit AES
- UPnP
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCI Express 2.0
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 3 x USB 2.0 - Type A , 1 x Ethernet 10Gb - SFP+
- Cables Included
- 2 x network cable
- Built-in 2 cooling fans
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- QNAP QTS 4.2
- 0 °C
- 40 °C
- 5 - 95%
