QNAP TS-1253BU-RP-4G 12 Bay NAS Rack Mountable
Quicklinx: D8B5WS00 Mfr#: TS-1253BU-RP-4G
  • Celeron
The TS-1253BU-RP is a rackmount NAS that easily fits into a standard rack, providing an ideal storage solution in the server room for small and medium businesses. The TS-1253BU-RP features a PCIe slot for boosting potential applications. The TS-1253BU-RP also provides a wide range of value-added features.
  • Extend NAS functionality with PCIe expansion
    The TS-1253BU-RP has a PCIe expansion slot, providing flexibility in extending NAS functionality and potential applications.
  • SSD cache acceleration
    The TS-1253BU-RP supports SSD caching. Users can install an SSD to boost IOPS performance of storage volumes.
QNAP TS-1253BU-RP - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
48.2 cm x 53.4 cm x 8.9 cm
16.14 kg ()
1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
10Mb LAN, 100Mb LAN, 1GbE
RAM
4 GB
Power Redundancy
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
48.2 cm
53.4 cm
8.9 cm
16.14 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 8 GB (supported) - DDR3L
Flash Memory Installed
4 GB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
NAT support, trunking, LDAP support, WOL, Syslog support, E-mail alert, print server, IPv6 support, STP support, download client, file sharing, TFTP support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, bandwidth control, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay, event notification, push notification, Chromecast support
Encryption Algorithm
SSL, FIPS 140-2, 256-bit AES
UPnP
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 0 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 1 x HDMI output
2 x network cable
Audible alarm, wake on LAN, built-in 2 cooling fans
Internal power supply
Power Redundancy
75.9 Watt
Power Provided
250 Watt
QNAP QTS 4.3
0 - 95%
Sound Emission
33.2 dBA
