QNAP TR004 4-Bay Expansion Enclosure
Quicklinx: F6X5WS00 Mfr#: TR-004
Type: Hard drive array
Controller Type: RAID
£196.30 ex VAT
£235.56 inc VAT
Effective storage expansion with RAID Support
The TR-004 is an ideal storage expansion solution for PCs, especially for laptops which lack the ability to install larger, higher-capacity drives. Featuring four 3.5-inch SATA drive bays and supporting RAID configuration, the TR-004 provides the ability to store a vast number of files and data and to ensure protection against potential drive failure.
The TR-004 USB 3.2 Gen 1 RAID expansion enclosure allows you to expand the capacity of your QNAP NAS and PC. The TR-004 can also be utilized as a DAS (Direct-attached Storage) device, allowing you to directly access its content just by connecting it via USB. The TR-004 features four 3.5-inch SATA drive bays with multiple RAID configuration options and USB 3.2 Gen 1 Type-C connectivity to bring you a highly reliable and secure storage capacity expansion solution.
  • Effective storage expansion with RAID support
  • Supports various RAID levels
    The TR-004 supports a variety of RAID configurations. Depending on your requirements, you can switch between hardware- or software-controlled RAID modes. Move the DIP switches to corresponding positions for your ideal RAID mode: Individual, JBOD, RAID 0, RAID 1/10 or RAID 5. You can also configure the RAID settings from your QNAP NAS, or by using the QNAP External RAID Manager utility on your computer.
  • Flexible storage configuration and management
    Compared with other RAID enclosures, the TR-004 provides software-controlled configurations for greater management flexibility. Users can configure RAID and monitor disk health using Storage & Snapshots Manager on a QNAP NAS, or by using the QNAP External RAID Manager utility on their computer.
  • Expand the capacity of your NAS
    The TR-004 provides an alternative method for users to expand their NAS storage capacity. By connecting the TR-004 to their NAS and using the Storage & Snapshots Manager, users can easily configure and manage their storage expansion. The TR-004 supports a variety of QNAP NAS storage and file management functions, allowing users to build storage pools, find files with Qsirch and organize files with Qfiling.
QNAP TR-004 - hard drive array
Hard drive array
Total Array Capacity
0 TB
USB 3.2 Gen 1
0 (installed) / 4 (max)
Supported Drives
SATA-300
Built-in Devices
Led panel
Storage Controller
RAID (SATA 3Gb/s) - RAID 0, 1, 5, 10, JBOD
Hard Drive
No HDD
Hard drive array
Chassis
Built-in Devices
Led panel
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage
0 TB
HDD Array External Interface
USB 3.2 Gen 1
Storage Controller
RAID
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
No HDD
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5" shared
1 x USB 3.2 Gen 1 - 24 pin USB-C
Security lock slot (cable lock sold separately), built-in cooling fan
1 x USB-C to USB-A cable
12 x screws (for 2.5" HDD), 16 x screws (for 3.5" HDD), 2 x keys, cable clip, power cable
External power adapter
Brand: QNAP
