Powered by an Intel Xeon D processor, the powerful enterprise-class TES-1885U is open for two operating systems - either the FreeBSD-based QES or Linux-based QTS. While QES supports ZFS for the utmost reliability and allows near-limitless snapshots, block-level data deduplication and real-time data compression, QTS features Qtier Technology, SSD cache, and an abundance of value-added apps to realize storage efficiency and diverse usage applications. The TES-1885U gives the flexibility to choose from two operating systems, enabling businesses to deploy proper operating systems on multiple TES-1885U based on their needs and goals in different stages.
Intel Xeon D processor optimizes performance and efficiency
Powered by an advanced 14nm Intel Xeon D-1531 6-core 2.2GHz 64-bit SoC processor with an integrated PCH, and with two built-in 10GbE SFP+ ports, the 12Gb/s SAS-enabled TES-1885U delivers outstanding performance for data transmission and applications. With a thermal design power of only 20-65W, the TES-1885U fulfills demands for both performance and energy saving. -
Excellent hardware: immensely, durable & compact
The TES-1885U supports SAS 12Gb/s 3.5"/2.5" drives, allowing for SAS 12Gb/s and SATA 6Gb/s hard drives and SSDs. Businesses can create the most cost-effective storage by implementing suitable drives based on their needs.
- QNAP TES-1885U - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 18 (max)
- 44.25 cm x 53.05 cm x 8.8 cm
- 15.1 kg ()
- Processor
- 1 x Intel Xeon D-1531 2.2 GHz (6-core)
- Storage Controller
- RAID SATA 6Gb/s / SAS 12Gb/s RAID 0, 1, 5, 6, 10, 50, JBOD, 60
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- IP Cameras Supported
- 80
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Storage Operating System
- QNAP QES 1.1 / QTS 4.2
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Windows 10 (32/64 bits)
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 44.25 cm
- 53.05 cm
- 8.8 cm
- 15.1 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- 6-core
- Max Supported Qty
- 1
- RAM
- 16 GB (installed) / 128 GB (supported) - DDR4
- Flash Memory Installed
- 4 GB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60
- Data Link Protocol
- TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS, SFTP
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- Load balancing, LDAP support, WOL, Syslog support, manageable, E-mail alert, print server, IPv6 support, High Availability, 256-bit encryption, firmware upgradable, proxy server, web server, backup server, download client, file sharing, event log, TFTP support, ACL support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, NAP, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, LACP support, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, RTRR
- Encryption Algorithm
- SSL, TLS, FIPS 140-2, 256-bit AES
- UPnP
Security DVR
- 80
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" , 6 (total) / 6 (free) - 2.5"
- Expansion Slots
- 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 2.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0 x4 , 1 (total) / 1 (free) x PCI Express 3.0
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb - SFP+
- Cables Included
- 4 x network cable
- Wake on LAN, AirPlay, built-in 4 cooling fans, hot-swappable fans
- FIPS 140-2
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 450 watt
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
