QNAP REXP-1620U-RP 16 bay Rackmount Expansion
Quicklinx: BSRQWS00 Mfr#: REXP-1620U-RP
Type: Storage enclosure
Controller Type: None
Hurry, only 1 left in stock!
£2,048.00 ex VAT
£2,457.60 inc VAT
The QNAP REXP-1600U-RP expansion enclosure is designed for expanding the storage space on the Turbo NAS and can support maximum 1 PB raw capacity by connecting multiple expansion enclosures via high speed mini SAS cables. This is especially useful for large data applications, such as video surveillance, data archiving, and TV broadcast storage.
QNAP REXP-1620U-RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 3U
0 (installed) / 16 (max)
Supported Drives
SATA-600 / SAS-3
Built-in Devices
Led panel
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
44.24 cm x 52.83 cm x 13 cm
18.14 kg
Storage enclosure
Enclosure Type
Rack-mountable - 3U
Chassis
Built-in Devices
Led panel
0
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-3
Hard Drive
No HDD
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
3 x SAS 12Gb/s , 1 x serial - 9 pin D-Sub (DB-9)
Lockable, built-in 3 cooling fans, hot-swappable fans
1 x SAS cable - 50 cm
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
204.4 Watt
Power Provided
650 Watt
44.24 cm
52.83 cm
13 cm
18.14 kg
5 - 95% (non-condensing)
Brand: QNAP
Price Range Ex VAT: 1500+
