QNAP REXP-1000 PRO/60TB-REDPRO 10 Bay Desktop NAS
Quicklinx: C624WS00 Mfr#: REXP-1000 PRO/60TB-REDPRO
The QNAP REXP-1000 Pro expansion enclosure is designed for expanding the storage space on the Turbo NAS by connecting multiple expansion enclosures via high-speed mini SAS cables. This is especially useful for large data applications, such as video surveillance, data archiving, and TV broadcast storage.
  • Plug and use, seamless capacity expansion
    Simply connect a REXP-1000 Pro to a Turbo NAS and power it on. The Turbo NAS will detect the hard drives in the REXP-1000 Pro as installed local drives. The Turbo NAS capacity can be expanded seamlessly by using the powerful QTS storage manager.
  • Missing mode protection
    When disconnection of the expansion enclosures occurs, the Turbo NAS enters missing mode automatically and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact when the disconnection is resolved.
  • High density, high efficiency and highly scalable
    The REXP-1000 Pro supports 10 hard drives and large raw capacity, and has two SAS wide ports for host connectivity and daisy-chain respectively. Each SAS wide port combines four SAS channels. The solution delivers unprecedented performance of up to 24 Gbps per host connection.
  • Powerful QTS storage manager
    The QTS storage manager neatly presents tools and options for managing system storage with an intuitive graphical user interface, which simplifies the process of NAS capacity expansion and REXP-1000 Pro management. IT administrators can easily monitor the health status of REXP-1000 Pro and the disks within it. When cascading multiple expansion enclosures in a rack, the locate disk and locate enclosure functions assist IT administrators for quick maintenance.
  • An excellent backup solution for the Turbo NAS
    In addition to expanding an existing volume, IT administrators can use the REXP-1000 Pro as a budget-friendly external storage to perform speedy and secure backup tasks for the Turbo NAS. The QNAP RTRR or sync service lets IT administrators back up the Turbo NAS data to the REXP-1000 Pro on a real time or scheduled basis.
  • Flexible drive selection
    The REXP-1000 Pro offers high flexibility in hard drive selection. IT administrators can choose enterprise-level SAS HDDs with high performance and high reliability for mission critical applications, low-cost but high-capacity SATA HDDs for large data archiving, or high-speed and high stability SSDs for I/O intensive operations.
QNAP REXP-1000 Pro - storage enclosure
Storage enclosure
Total Array Capacity
60 TB
SAS 6Gb/s
10 (installed) / 10 (max)
Supported Drives
SATA-600 / SAS-2
Built-in Devices
Led panel
Storage Controller
(SATA 6Gb/s / SAS 6Gb/s)
Hard Drive
10 x 6 TB HDD SATA 6Gb/s - hot-swap
AC 120/230 V - 47 - 63 Hz
32.7 cm x 32.12 cm x 21.75 cm
9.24 kg
Storage enclosure
Chassis
Built-in Devices
Led panel
10
Supported Devices / Modules Qty
10
Supported Drives
SATA-600 / SAS-2
Storage
60 TB
HDD Array External Interface
SAS 6Gb/s
CPU
No CPU
Storage Controller
Interface Type
Data Transfer Rate
600 MBps
Max Storage Devices Qty
10
Hard Drive
HDD - hot-swap
10 x 6 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
10 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x SAS 6Gb/s (input) , 1 x SAS 6Gb/s (output) , 1 x serial (management) - 9 pin D-Sub (DB-9)
Security lock slot (cable lock sold separately), built-in 2 cooling fans
1 x SAS cable - 50 cm
Software Included
Drivers & Utilities
Internal power supply
Power Provided
350 watt
32.7 cm
32.12 cm
21.75 cm
9.24 kg
5 - 95% (non-condensing)
Sound Emission
34.6 dB
