QNAP QSW-M408-4C - switch - 12 ports - Managed
Quicklinx: FXJBWS00 Mfr#: QSW-M408-4C
Type: 10 Gigabit Ethernet
Ports: 12
Managed: Yes
£349.68 ex VAT
£419.61 inc VAT
The QSW-M408 is a switch equipped with four 10GbE SFP+ ports and eight Gigabit ports. Supporting layer 2 switching and network management via user-friendly web user interface, the QSW-M408 offers flexible deployment in a hybrid high-speed network infrastructure and an entry-level network management solution for even non-IT professionals.
  • Flexible deployment
    The QSW-M408 provides four 10GbE SFP+ ports and eight Gigabit ports for connecting various devices and enabling hybrid high-speed networks. With SFP+ interfaces, direct attach copper (DAC) cables can be used for connecting directly to SFP+ devices.
  • Intuitive web GUI
    The QSW-M408 uses the QNAP QSS, which features an easy-to-use web GUI with value-added functions to simplify network set up and management.
  • Sleek design
    Use the at-a-glance major functions, flat control layers and one-click login to simplify set up and management.
  • Value-added functions
    With the setting guide, status chart reference, online firmware update, the learning and management costs are greatly reduced.
  • Optimize network performance with bandwidth and packet control
    The QSW-M408 provides bandwidth and packet control functions (such as LACP, VLAN, QoS, and IGMP snooping) for boosting network performance through IP grouping and bandwidth management.
  • Faster speeds using existing cables
    The QSW-M408 is compatible with 10GbE and NBASE-T technologies to support up to five speeds. The combo ports provide higher transmission speeds with existing cables. Depending on cable types and their lengths, different speeds can be achieved for faster, more efficient data transfer.
  • Desktop size for easy use in offices
    With a compact and modern design, the QSW-M408 fits perfectly alongside other devices in modern digital offices. Featuring a delicate design, the QSW-M408 helps users to easily identify each port.
Switch - 12 ports - Managed
Subtype
10 Gigabit Ethernet
Ports
8 x 10/100/1000 + 4 x combo 10 Gigabit SFP+
Performance
Switching capacity: 96 Gbps , Non-blocking switching throughput: 48 Gbps
MAC Address Table Size
16K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMP, IGMPv2, IGMPv3
Remote Management Protocol
RSTP
Web-based management, Energy Efficient Ethernet, IPv4 support, LACP support, port-based VLAN, VLAN management, LLDP support
IEEE 802.3, IEEE 802.1p, IEEE 802.3ab, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz, IEEE 802.3u, IEEE 802.3x, IEEE 802.3z, IEEE 802.1Q, IEEE 802.1w, IEEE 802.3ad (LACP)
AC 120/230 V (50 - 60 Hz)
29 cm x 12.7 cm x 4.25 cm
1.15 kg
Enclosure Type
Desktop
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9KB
Routing Protocol
RSTP
Status Indicators
Power, port transmission speed, link/activity, status
4 x 10GBase-X RJ-45/SFP+ , 8 x 1000Base-T RJ-45
External power adapter
31.46 watt
Power cord
29 cm
12.7 cm
4.25 cm
1.15 kg
Shipping Weight
1.57 kg
45 °C
5 - 95% (non-condensing)
Ports: 12
Managed: Yes
Brand: QNAP
