The QNAP QSW-804-4C is an unmanaged switch, allowing you to instantly upgrade your network environment in a cost-effective way. With high performance, low latency and superb functionality, the QSW-804-4C is the ideal choice for upgrading your home or business connections.
- QNAP QSW-804-4C - switch - 8 ports - unmanaged - rack-mountable
- Switch - 8 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- 10 Gigabit Ethernet
- Ports
- 4 x 10 Gigabit SFP+ + 4 x combo 10 Gigabit SFP+
- Performance
- Switching capacity: 160 Gbps
- Capacity
- Priority queues: 8
- MAC Address Table Size
- 27K entries
- Jumbo Frame Support
- 9KB
- Flow control, full duplex mode, Energy Efficient Ethernet, CoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
- Power
- AC 120/230 V (50/60 Hz)
- 28.5 cm x 23.3 cm x 4.3 cm
- 2.1 kg
- 2-year warranty
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Ports
- Performance
- Capacity
- 27K entries
- 9KB
- Status Indicators
- Port transmission speed, power, link/activity
- 4 x 10GBase-X SFP+ , 4 x 10GBase-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 41 Watt
- Rack Mounting Kit
- Included
- 28.5 cm
- 23.3 cm
- 4.3 cm
- 2.1 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
